Basspakke selges - Kenwood sub, A/D/S, Prosonic Kondensator
Strato
ANLEGGET ER SOLGT.
2 stk. KENWOOD 12' BASS , 1200w, KFC-W3012 ,30cm Component Subwoofer i kasse.
Kjøpt i sommer hos Kongsberg HI-FI senter.
Link:
http://pal.finn.no/pal/bap1/bap/object?finnkode=18059527&sid=
Key Features
300mm P.P.Cone with fiber texture
1200W Maximum Input Power
Push Terminals
Super Linear spider
Reversible gasket
High-roll uerthane surround
Double stags magnet
Speaker Features
Speaker Type Subwoofer
Peak Input Power 1200W
Rated Input Power 400W
Speaker Size 300mm
Speaker Cone Design Stainless Coated Cone
Magnet Type Ferrit
Terminals Silver-plated Push Type
Magnet Cover Rubber
Gasket Installation two-sided
Installation Capabillity Sealed/ Ported
Speaker/woofer Specifications
Maximum Input Power 800W
Woofer Cone material Injection P.P. Cone
Speaker Basket Steel
Speaker Surround High-roll urethane
Spider Type Super Linear Spider
Sensitivity 86dB/W/m
Frequency Response 39Hz ~ 300Hz
Subwoofer Impedance 4& x 1
Dimensions (W x H x D) 326 x 326 x 174.3mm
Mounting Depth 156.8mm
Mouting Hole Diameter Ø 279.3mm
Speaker Weight 6100gr
Weight of Magnet 1780gr
Subwoofer Parameters
Nominal impedance (Z) 4&
DC resistance (Re) 3.4&
Resonant frequency (FSO) 31Hz
Mechanical Q factor (QMS) 11.864
Electrical Q factor (QES) 1.107
Total Q factor (QTS) 1.012
Voice coil inductance (LBM) 1.4mH
Voice coil diameter (d) 65mm
Force factor (BL) 9.8T/m
Peak excursion Xmax 13.8mm
Moving mass (MMS) 158.8gr.
Volume accoustic compliance (VAS) 62liter
Piston Area (SD) 0.052m²
a/d/s P700.1, 1 kanals sub-forsterker, 2800W maks, 420W RMS v/ 4 ohm. Kostet 1990,- på Torshov bilrekvisita.
Prosonic kondensator 1 Farad m/neonlys og voltmeter. Beskyttelseskrets mot feilkobling. Auto on/off.
Dette har sittet kun i sommer i min generasjon 1 V70. Fikk taket til å bule. Mål på kassen er følgende:
91cm bred
40,5 cm høy
35,5 cm dyp
Tror denne er bygd hos Fort Knox i Drammen. Ikke 100% sikker hvilket firma som har bygd denne. Solid kasse.
Med forsterker/kondensator så går det vel opp til nærmere 50 cm dyp. Dette gikk akkurat under rollo med litt buling på denne.
Alt sitter samlet på kassen. Selges for kroner 2000,- grunnet kjøp av nyere V70 med integrert anlegg. Utstyret kan hentes i Drammen eller i nærheten.
Har også en Ultimate-Sound TA4600 som jeg selger for 500 kroner. Har drevet 6x9 i bilen.
Output RMS Power at 4 Ohms
85 W x 4
Power at 2 Ohms 125 W x 4
Endret av Strato
03 V70 D5
