Beste motorrens? Tips/erfaringer?
tipetu
Ville vel kikka mot de store, som Tunap, Omega eller Forte.
Husker jeg fyllte injection rens på en Nissan FJ20E motor som hadde gått 320 000, merka ikke noe forskjell, men ved en sjekk i dysetaster sprøyta alle dysene nært perfekt, om dysene bare var bra eller om det faktisk utgjorde en forskjell vet jeg ikke.
Husker selvfølgelig hvilket merke den rensen var, men var en type man fikk kjøpt på de fleste bensinstasjoner, i tiden før alle tilstningene som skulle fikse alt kom for fullt på det norske markedet.
Flat flaskeformet flaske
Æres Super Moderator
`92 Ford Scorpio 2.9 GL
jaaaaaaa en skvett tynner å litt kondensfjærner å man har en billig blanding ,,
Techron Concentrate
Distillates, hydrotreated light < 50 %weight Aka: Paint thinner(oil based)
Stoddard solvent < 35 %weight Aka: dry clean solvent, white solvent
Solvent naphtha, light aromatic 5 - 10 %weight : zippo lighter fluid
Benzene, 1,2,4-trimethyl- 95-63-6 1 - 5 %weight : powerful toxic solvent
Xylene , powerful solvent
Techron is naptha and 3 kinds of benenze.
GUM OUT INJECTOR CLEANER (WINTER GRADE)
Chemical Percent
Trade secret or proprietary formula < 1 ( secret #1)
Petroleum distillate(s) (unspecified) 40-70 ( most likely paint thinner)
Detergent/Inhibitor mixture 1-10 ( secret #2 )
Isopropanol 30-50 (rubbing alcohol, GAS DRYER "CH3CHOHCH3")
I can not begin to guess why we need more alcohol when all gas has it already.
Gasoline, must contain 2% oxygen by weight, in most smog chocked areas of the USA.
Seafoam ingredients:
1 PALE OIL 4229 40-60% = A base or process oil refined until its color = yellow.
2 NAPHTHA 20 25-35% solvent powerful , common in all good injector cleaners. Zippo juice !
3 IPA 125 10-20% = Isopropyl Alcohol (rubbing alcohol), Useless in gas , cuz it already has tons.
in my opinion , putting oil into your gasoline is not too smart. Think about it?
fouls plugs, makes lots of carbon , and messes up OXy sensors. You decide.
"GM TEC" ingredients:
2-BUTOXYETHANOL, a paint and ink solvent , used even in Clorox cleaner 409
Naptha, , raises octane rating of gas, , simular to Zippo ligher fluid. Coleman camp fuel.
4-METHYL-2-PENTANOL, (aka:Methyl isobutyl carbinol) used as a lacquer paint tinner
9-OCTADECENDIC ACID.(aka:Oleic acid, found in Olive oil) ( this acid is interesting)
BG-44k: ( madly popular but little different than old Chevron Techron)
Light Aromatic Solvent Naphtha , ( Zippo lighter fluid)
1, 2, 4-Trimethylbenzene , commonly found in up to 7% by volume already in Gasoline.
Xylene ,(1,2-dimethylbenzene & 1,3-dimethylbenzene & 1,4-dimethylbenzene), xylol , powerful solvent
Cumene ,(isopropylbenzene, ) powerful solvent,raises octane of gasoline.
GUNK , RADIATOR SPECIALTY COMPANY, FUEL INJECTION AIR INTAKE CLEANER
2-Propanone 30-60 % aka: Acetone
Ethylbenzene >10 % a powerful solvent
Hydrotreated Heavy Paraffinic Distillate 1-10 % weak solvent
Methanol 1-4% , solvent.
Propane 10-30% , gas
Toluene 15-45% ,powerful solvent
Xylene (mixed isomers) 5-20%
Red Line SI-1
1-5% Alkenylamine - (a detergent ,even used sometimes,in baby shampoo)
1-10% Isoctanol - ( C8H18O , aka, 2-ethylhexan-1-ol, or Octyl alcohol)
1-10% 1,2,4 Trimethylbenzene , (C9H12 )
5-20% Aliphactic Napthta , zippo lighter fluid. , aka: white gas, low octane)
Valvoline Complete Fuel System Cleaner
52 - 62% Kersosene
28-38% Light hydrotreated petroleum distillate
6-16% Stoddard Solvent ( stoddard is the name of the man who invented dry cleaning)
Warning, some of the chemical names have 20-30 synonyms."
Endret av vølvø
