Stor Bilstereo Selges/Byttes
erlend_evensen
Kom med BUD ev. bytte
Alt er i tipp topp stand.
Ny pris på alle componenter:81740,-
DLS ULTIMATE series A6 1 ohm stable monoblock x2
RMS output per channel at 13,8 volts, < 0,1% distortion.
Mode : AB
Number of channels : 1 for subwoofer use
Nominal power in 4 ohm : 500 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
Terminal for external cooling fan : Yes
Dual DC-inputs : Yes
Phase control 0-180 degrees : Yes
Remote sub level control : Yes
Current draw, idle : 0,6 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
Ny pris: 6490,- pr.stk
DLS A4: Ultimate A series - 4x85w x2
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Number of channels 4
Amplifier class AB
Typical power in 4 ohm 4 x 85 W
Typical power in 2 ohm 4 x 145 W
Typical power in 1 ohm 4 x 220 W
Mono bridge mode 4 ohm 2 x 250 W
Mono bridge mode 2 ohm 2 x 400 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 50 kHz
Input impedance, high level N/A
Input sensitivity 0,2 - 7 V
Input impedance > 10 kohm
Filters channel A & B LP: 50-125 Hz. HP: 20-200 Hz / 60-600 Hz
Filters channel C & D LP: 45-200 Hz / 90-400 Hz. HP: 20-200 Hz
Dual DC inputs 1
External cooling fan terminal 1
Power consumption (idle) 1,5 A
Power consumption (max) 95 A
Rec. power cable Minimum 4AWG / 21 mm2
Dimension (W x D x H) 465 x 240 x 73 mm (18,30 x 9,45 x 2,87 inches)
Weight 6,6 kg ( 14,55 lb)
Ny Pris:8990 pr.stk
DLS UR10 - 10" subwoofer
Speaker type
: Subwoofer
Impedance
: 2 x 4 ohm
Size
: 10" (25 cm)
Power handling capacity
: 400 W RMS / 700 W max
Frequency range
: 25-2000 Hz
Sensitivity
: 85,6 dB (1W/1m)
Magnet size
: 180 mm (7,1"), 180 oz
Outer diameter
: 264 mm (10,39")
Installation depth
: 133 mm ( 5,24")
Mounting hole
: 236 mm (9,29")
Weight
: 9,1 kg (20 lb
X-max
: +- 12 mm (0,47")
Fs: 42,3 Hz
Re: 1,92
Qes: 0,40
Qms: 5,62
Qts: 0,37
BL: 13,1
Vas: 13,9 l (0,5 cuft)
NY pris:4990,- pr.stk
Pioneer ODR RS-d2 spiller med odr kabler osv
NY pris 12000,-
Pioneer Avic 1 som ny
Ny pris 14900,-
Pioneer avx 7000 DVD/skjerm
ny pris 13900,-
Toyota Arctic Truck "35 00(Vinter)(Til Salgs)
Audi S3 03 (Bruksbil)
Honda Civic Turbo 97 (Extrem)
Sponsor: http://WWW.MCARDESIGN.NO
http://WWW.AT-PERFORMANCE.NO
