Multimedia i bil
Mac
Heisann...!!
Har lenge gått med tanken om en bil med mye multimedia inkludert..
Har nå finne en pakke jeg tror vil funke.. Men før jeg kjøper, måtte jeg se om det var folk som hadde erfaringer med disse tinga..
Først headuniten:
Key Specifications/Special Features:
Characteristics:
DVD/VCD/DVCD/SVCD/CD/CDR/MP3 Compatible
50W X 4 High Power Output ( MOSFET Power IC)
Sanyo Deck & Toshiba Servo
Region Free (Code Free, Multi-Region, All Region)
AM/FM/MPX Stereo Play
30 Preset Station Auto Memory Store/Preset Scan
MP3 Slection by Sequence Number & Track Name - ID3Tags Display
Jumbo Multi-Color LCD Display with White Blacklighting
Automatic Color System NTSC PAL or PAL60 Switchable
16:9, 4:3 Letter Box and 4:3 Pan Scan Aspect Ratio
OSD display on TV Of MP3: Directory Root Menu / Cursor Position of Mp3 Files Name / Elapsed Time / Elapsed Track / Total Track Number
Multiple Angles / Multiple View / Multiple Audio Functions
Preset EQ ( POP / Rock / Classic )
Dancing Level Meter
Power On Greeting Display
Electronic Audio Controls Vol/Bas/Tre/Bal/Fad
Mute/Loud Control Lock
2 Channel RCA Preamp Output
Card Size Full Fonction Remote Control
16 Pin Wire Harness Connector
Multi-Function Remote Control
DolBy Pro Logic Surround Encoder For Surround Sound
Anti-Shock Feature
Detachable Faceplate For Added Security
Soft Tough Buttons And Controls.
ZOOM To Enlarge Picture
ISO Moutng Chassis
Full SMT Assembly
Slot type Disc Feeder
DC Input (10-12Volt) with 8-16 Volt Limit.
Accessories:
In-Dash Car DVD Player
FrontPanel Protection Cover
Connection Cable
Remote control w/ batteries
User's manual
http://www.mp3playerstore.com/stuff_you_need/dvd/dvd-0181.htm
Så lcd skjermen:
Main Features:
-Active Matrix TFT LCD Monitor
Model with Built-in Speaker
-Super slim
-Stable performance with high picture quality
-Screen size: 5.6 inches (diagonal) 4:3
-Full color Pix: 960(H) X RGB x 240 (V)=230400
-Inverse image option
-Viewing angle (L/R: 50 degrees U/D: 25 degrees)
-NTSC/PAL auto switchable
-Full function remote with OSD
-Power supply: 11-15V DC
-Power consumption: 7W
-Dimension: 153 x 133 x 28mm
-Power supply: 12V DC < 700 mA
Warning: Don't supply more than 12V
As it will damage the monitor!
Ready to GO Package:
-LCD Monitor & Support
-Infrared Remote
-Connection cable with 1 video input,
1 audio input and one DC jack.
Special add on by us!
-Car adapter
-110V-220V Intl WALL ADAPTER
( We also supply Europeen Plug for Intl Order)
http://www.mp3playerstore.com/stuff_you_need/special/th-5688.htm
____________________________________
Hva tror dere? Noen som har erfaringer med Innovatek?
Noen av tinga som jeg lurte på har jeg spurt firmaet om...
Forresten så står det ikke noe om styrestrøm til extra amp, men det er vel det? IMG funker visst ikke!
Takker for svar... :cool:
-> Bmw 328i E46
X - VW Caddy 07 X - Hyundai H1
X - Nissan 200SX S13
X - Nissan Primera P10
X - Toyota Tercel ;p X - Toyota Corolla :p
Originally posted by ALJ_GSi
sjekk http://www.soundpressure.no der trykker du på bilstereo og så på pyle. der finner du mye bra multimedia løsninger til en bra pris. siden er under bygging så det ligger ikke så mye der enda. trykk også på pyle linken på høyre siden
Takker for linken..
Men jeg har vel egentlig finne produkta jeg er på jakt etter...
Tror prisen inn til Norge blir 3462,92kr inkl Mva..
Forresten, er det mer en Mva man må betale tru?
Har tatt med "International - DHL Express - Insurance included" i prisen så..
Kan vel ikke klage på prisen, komplett sett!
-> Bmw 328i E46
Originally posted by Mac
Takker for linken..
Bare sånn for å ha advart deg, den skjermen der vil du garantert få problemer med. Samme type som vi hadde på test hos oss i fjor med tanke på import, Men da gikk den under navnet PLATIN GATE. Fyfaen for noe drit, vi hadde tatt inn tre skjermer alle 3 smeltet pga varme utvikling. Sånn da har jeg ihvertfall advart deg. Så får du bestemme deg om du vil gå for den eller ei.
MVH
ROY
På lånt iD av ALJ_GSI
Kun råeste!!
MVH
ROY
Ups her har Andreas vært og laget et nick på butikken. Det er bra. HEHE da er det ikke lenger en lånt ID.
Kun råeste!!
MVH
ROY
Au da... hva med: Denne da
Har dere teste forskjellige modeller fra de? Eller bare en, den jeg vurderte?
-> Bmw 328i E46
Ikke bra synsvinkel på den skjermen... Du må nesten sitte direkte foran.
-Power supply: 11-15V DC....
Javel... Men hva står det lenger ned?
Kanskje ikke rart at Soundpressure hadde problemer med denne...
Vel må si meg enig med Bissarre i at det ikke er verdens beste synsvinkel på den der.
Har tittet litt på siden til det firmaet og de produktene de har, Alle produktene lingner veldig på det vi testet i fjor, og vi forkastet mesteparten. En annen ting jeg ville ha tenkt på er holdbar heten til de produktene, sikkert ikke verdens beste. Og når du da i tillegg kjøper fra utlandet blir det også en risko i dette. Hva med garantier og slikt.
Klart det ser billig og forlokkende ut, men det er jo også en grunn til det! produktene er billige og ikke veldig bra. Sats heller på produkter og leverandører du kan stole på, og ikke minst få hjelp fra hvis noe skulle oppstå.
Mvh
Roy
Kun råeste!!
Muligheter for at det kunne ha vært det... Jeg har tenkt å bruke styrestrømmen fra cd-spiller te det.. den gir jo 12 stabilt?
Skal ikke banne på dette... Men jeg trur nok at spenningen ut fra remote på spilleren er lik ladespenningen. 13,8-14,4volt.
Samtidig er ikke den remote utgangen strømsterk. Du skal ikke koble på noe særlig der, før utgangen ryker.
I og med at folk har delte erfaringer her... Så tenkte jeg på å kjøpe et anna merke: DigitalWW
Denne ser mye mer kvalietetsmessig ut en den andre over. Eller hva tror ekspertene?
;) :D
-> Bmw 328i E46
