tharealbassmachine Skrevet Desember 4, 2009 Rapporter Share Skrevet Desember 4, 2009 hei selger en re audio xxx 12" er solid og kraftig sub ! specs: Electrical Q Value -Qes: 0.46 Mechanical Q Value -Qms: 3.29 Total Speaker Q Value -Qts: 0.404 Free Air Resonance -Fs: 21.00 Hz Equivalent Compliance -Vas: 74.0 liters One-Way, Linear Excursion -Xmax: 54 mm Efficiency -SPL 1W/1m: 83.76 dB SPL Effective Piston Area -Sd: 480 cm^2 DC Resistance -Re: 4.2 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 2000 W Force Factor -Bl: 18.16 Mounting Depth - 12.75" Mounting Hole Diameter - 11.5" Overall Diameter - 13" Bolt Hole Circle - 12.25" Motor Width - 10.5" Motor Depth - 5" Basket Depth - 7.75" Displacement - 0.24 cu. ft. Weight - 72 lbs. har noen små riper i lakken men ellers helt fin! byttes/selgest kr 5500 ta gjerne å kontakte meg med pm eller hotmail voldan11@hotmail.com Mvh Daniel s.h Siter Nissan 200sx s13 1990mod Lenke til kommentar Del på andre sider More sharing options...
