Selges: MSD Blaster SS Coil
Velger å selge min MSD Blaster SS Coil på grunn av bygging av ny motor hvor jeg allrede har dette montert, her er litt spec:
Don’t let the compact size of the Blaster SS Coil fool you, because it is packed with performance! The efficient E-core windings are designed to produce high amounts of current without sacrificing the voltage output. In fact, when used with an MSD 6 Series Ignition, the Blaster SS produces 300 milliamps with a maximum voltage output of 40,000 volts!The secondary windings are wound on a segmented bobbin which reduces the chance of voltage breakdown between the primary and secondary windings. For more protection, these windings are encased in a polyurethane compound for complete protection against vibration. The Blaster SS features brass terminals and a sturdy Rynite housing. It is supplied with a 90° boot, terminal and vibration mounts. A great addition to CD Ignitions and some stock applications.
Selges til første mann med 1500,- sendes kun mot forhåndsbetaling
Vennligst ta kontakt via e-post: ronnie_vindheim@hotmail.com
Bilene mine:
vw caddy mk1 86 modell (prosjekt)
vw golf mk1 83 modell (ikke bestemt)
vw golf mk3 92 modell (bygges om)
vw golf mk3 vr6 delebil
