kjetil1972 sin 220TE Sportline
kjetil1972
her er min 1992 mod s124 med 500e kitt.
datakort på biln
VIN WDB1240821F246362
Model 220 TE / E 220
Chassis 1240821F246362
Engine 111960 12 004517
Transmission 722428 03 275802
Order 0 2 216 03086
Heating 0-21612735
Lights HELLA
Wiper BOSCH
Delivery date 12.11.92
Dealer Duesseldorf branch (216)
Interior leather black / anthracite (271)
Paint
199 metallic blue-black (с 01.01.1983)
Options
244 sports seats, front (с 01.07.1986)
260 elimination of model designation on rear lid (с 01.05.1968)
281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
412 electric sliding roof with tilting device (с 01.07.1983)
420 automatic transmission, floor shift (с 01.01.1963)
537 mechanically operated antenna and front loudspeaker - without radio set (с 01.10.1989)
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
620 emission control system vehicles with catalyst technique (с 01.03.1985)
653 sports chassis with 8-hole light alloy rims (с 01.01.1990)
731 wood trim, burred walnut root (с 01.08.1980)
812 rear-mounted loudspeaker (с 01.11.1974)
855 telephone TELE-AID, Nokia, D-net
873 seat heater for left and right front seats (с 01.02.1984)
953 rotating emergeny flasher, central front (blue light)
sportline with 8-hole rim (consisting of codes 65/3,244,281) (с 01.02.1991 по 30.09.1996)
ett par bilder slik den er nå...
på bildet har jeg 8,5x17 borbet felger med 225/45 vinterdekk.
til sommeren har jeg amg replica felger 8,5x17 med 235/45 dekk.
skal opplakkeres i løpet av våren i orginalfargen.
mulig blir innkjøpt senkesett etterhvert,er orginale sportlinefjærer på den nå.
kom gjerne med forslag/innspill om hva jeg burde gjøre eller ikke gjøre med kjerra :)
    VW Passat 2.0TDI  2006
 X Audi S6 2,2 20VT  1997
 X Audi A6 2,5TDI Quattro 2001
 X Audi A6 2,5TDI Quattro 1996
 X Mitsubishi Pajero 3000 Fjallasport 1992
 X mitsubishi Pajero 3000 1991
 X Volvo V70XC 2,5T 1998
  • Svar 41
nydelig....:)
er som ett sjakkbrett i forskjellige farger nå, grå og svart ommhverandre. blir bra når jeg får den lakkert, tror jeg :)
funderer på å lakke all krom sort silkematt..."mafialook"
Denne ble jeg meget nysjerrig på... politibil?
hakke peiling.... er bruktimpotert i 2001 fra tyskland.
kjøpt på auksjon på stadssalg.no ,har lite/ingen innfo om hva den er brukt til :(
biln er blitt noe si over hoftene etterhvert,ja :)
venter med senking til sommerluggene skal på...
fulgte med ett H&R senkesett, men har inga peiling på hvor mye det senker biln. inga papirer på det heller.
Endret av kjetil1972
  • 4 weeks later...
da det ser ut som det drøyer litt ut på våren før jeg får plass i garasjen til lakkering.. sprøytet jeg frontfangeren og saccoen på forskjermer og bakskjermer midlertidig alto-grå :)
ett bilde i bredd med brodern sin S124
Noen som har fjerna bakpotta på s124?
synes den er fæl,tenkte å finne en flat liten potte istedet for den.
ser foresten nå at jeg må få biln senket bak :m'm:
legger ved ett par bilder innvendig også :)
har du rakt rør istedet for potta??
mye bråk?
har egentlig lyst til å fjerne slepekroken også :)
måtte det bare bli sommerføre,litt spent på hvordan det blir med 255/40 dekk :)
mye bråk?
fjærna bakerste dempern. blei litt mer lyd men ikke overdrevent mye.
drivå fikse mæ ny bakfanger nu så slepekroken min skrues av.
blir flott med sommer felger. du kjøre vel ikke med 255 fremme??
bestilt 265-35 bak og 245-40 framme. så blir artig å se kor ukomfortabelt det blir. :P
-Bmw E36cab, Mercedes s124, Volvo 244
X Mercedes 190E 2.0D, SaaB 9000 Turbo 16v 1986, saab 900T -95, Toyota Hi-lux korta -83 3"BL og 33"dekk
Gratulerer, nydelige biler ! Har den gått langt eller ?
Jeg har gjort samme som deg med bakpotta på min 96 e230, ble helt perfekt lyd. Ganske diskre lyd, men endel dypere.
82 Mustang 302 med 280/290 kam,porta topper,
Speed-Pro Hypereutectic w/ Coated Skirt stempler,Accel/Malloy tenningssystem,osv osv
96 Mercedes E230
87 Bmw e30 325i. Var pen og trimmet, men ble knust av en "kamerat" :(
er noe slitte 235/45 på de nå,hadde tenkt å bestille 255 dekk...
tror du det blir sporing med de?
skal på biltilsynet for godkjenning av senking,bredding og hjul, de er sikkert ikke så glad i forskjellig dim. forran og bak.....????
går biln gjennon EU uten bakpotta???
er omtrent slik som denne biln den blir seende ut.... etter planen da :) http://www.finn.no/finn/car/used/object?finnkode=21053471
blir første sesongen med slike dekk på meg så kan ikke svare på det med sporing. :(
trur du må ha papirer fra mercedes på forsjellig dim! :/ men er litt usikker på det. bare å krysse fingrene å høre.
har laga "rakarør" fra der eksosn er delt over bakakslingen. så tar 15-20 min å hive på det orginale. orket ikke prøve me rakarøret engang. :P
Ser ut som det vil bli en kjempefin S124. blir vel mye loding på finnsnes! :P
loding :) tror ikke det blir så mye loding på meg :)
tror/håper det skal gå bra....
hadde litt antydning til sporing med 225 dekkene før jeg gikk opp til 40psi. etter var det ingenting :)
mener det var 255 dekk brodern hadde på 500Een. funket fint på den ihvertfall...
har tenkt å bestille disse dekkene
http://www.nordendekk.no/Sommerdekk_17_tum_Yokohama/products/237351/255-40_YR17_TL_94Y_YOKO_S01_SDRIVE.html
håper det ikke blir no sporing. ødelegger mye kjøreglede.
var jo ei billig side med dekk da. trur jeg må bestille derfra jeg å. 3900 med frakt for samme dekkene som jeg skulle få i Tromsø. der skulle dem ha 8000+ men det var færdi omlagt og balansert. men det e jo svindyrt. :p så blir bestillt på nett.
hvordan felger er det du har å skal ha på??
