Kobling av anlegg
solve92
  • 4 weeks later...
Pin-What It Is In Dash Wire--Color------------------------Equivalent Wire Color
A---Right Front Speaker (+)--Green-----------------------Gray
B---Left Front Speaker (+)---Pink--------------------------White
C---+12 Volt Ignition Wire---Gray--------------------------Red
D---+12 Volt Battery Wire----Blue w/ Yellow Stripe--Yellow
E---Right Front Speaker (-)--Blue-------------------------Gray w/ Black Stripe
F---Left Front Speaker (-)---Purple------------------------White w/ Black Stripe
G---Ground Wire--------------Black-------------------------Black
H---Power Antenna Wire 1----------------------------------Blue (join wires 1 & 2
I---Power Antenna Wire 2----------------------------------together to this blue wire)
J---Do Not Use
K---Right Rear Speaker (+)---Red---------------------------Purple
L---Left Rear Speaker (+)----Black-------------------------Green
M---Right Rear Speaker (-)---White-------------------------Purple w/ Black Stripe
N---Do Not Use
O---Do Not Use
P---Left Rear Speaker (-)----Yellow-------------------------Green w/ Black Stripe
normalt legger man bare opp en ny(blå) ledning bak til forsterker selv
1991 bmw e34 520i
1987 toyota camry 2.0 xli = vraka
J---Do Not Use
N---Do Not Use
O---Do Not Use
Hvor fant du ut dette? prøver å finne ut det samme til min yaris!
fant for 07 modell da
http://www.modifiedlife.com/stereo-radio-wiring-diagram-2007-toyota-yaris/
2007 Toyota Yaris Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: White/Black
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
1991 bmw e34 520i
Skjønner ikke helt hvorfor du skal finne en original remote-ledning, da du sannsynligvis ikke får brukt denne til noe uansett. Hvis det i det hele tatt er noen. Det beste er å legge opp en ny ledning, f.eks 1,5mm^2, sammen med strømmen bakover.
Super Moderator
  • 11 months later...
  • 1 month later...
  • 1 month later...
Hei! Jeg har kjøpt meg en gammel 94 modell camry stv. som jeg må bytte radio i.
Har koblet en del anlegg opp igjennom årene, men her kommer jeg til kort.
Vanligvis på nyere spillere så går den ene kontakten til strøm og den andre til høytalere, men her er det noe rart.
AC kutter ut hvis radio ikke er koblet til.
Får ikke strøm på spiller ved å koble gul, rød og sort til tilsvarende på ny spiller. Har dere noen tips til hvordan jeg fikser dette selv?
På min andre bil, en opel vectra, så fikk jeg kjøpt en spesialkontakt som gjorde at alt fungerte. Er det noe tilsvarende jeg kan gjøre her, eller burde jeg reise ned til Toyota i Sarpsborg og bestille en time der?
Nissan 200SX RS13 med trivelige mods.
www.sandvik-bros.com
