Ny kicker l7 10" selges!
braendaas
Selger 1 stk Kicker - Solo Baric L7 10" (2x4 ohm) 1200W.
Elementet er nytt og ikke brukt.
Ligger i orginal embalasjen.
Selges da jeg ikke får bruk for det.
Kan være behjelpelig med frakt Kristiansand - Porsgrunn.
Sender gjerne!
SELGES FOR 1500,- !
Ta kontakt på 48 12 76 44 eller send mail til braendaas@mac.com. Ikke PM!
Litt info om elemtentet:
Max effekt 1200 W
RMS effekt 600 W
Impedance 2 x 4 ohm
Frekvensområde 24 - 100 Hz
Følsomhet 86.8 dB
Monteringsåpning 237 mm
Monteringsdybde 159 mm
FS -
VAS -
QTS -
Anbefalt kassevolum lukket 18.7 - 28.3 L
Anbefalt kassevolum bassrefleks 35.4 - 63.7 L
Veil. Pris 4000,-
In 2008 the newest KICKER Solo-Baric® L7 Subwoofer remains the most capable subwoofer on Earth. Without question, it’s the best-looking, best-sounding square subwoofer available. And it’s the only patented one that provides more cone, more air, and more decibels.
KICKER engineers left it all on the table for this redesigned Solo-Baric L7, taking cues from the award-winning original that debuted as groundbreaking at the turn of the millennium, and then improving on them. Let there be no doubt, it’s the most complete KICKER subwoofer ever developed.
Available in 8-, 10-, 12-, and 15-inch models, the Solo-Baric L7 still revolves around the breakthrough SoloKon™, the one-piece, injection-molded cone with full-coverage back bracing that pushes more air and creates louder bass than any like-size round subwoofer. It’s good enough that KICKER uses SoloKon across the board as the cornerstone for each subwoofer in the KICKER bass-making family.
SoloKon may be a rock star, but it’s the unshakeable motor structure behind the scenes that propels it to the forefront. Minor tweaks have given the motor an outstanding rep – dual high-temp voice coils, poly-cotton semi-progressive spider, Spiralead™ tinsel-lead technology, highly-efficient UniPlate™ pole-piece/back plate, and a heat-reducing T-cut top plate for enormous power handling. And it’s never been cooler with a new solid pole piece that disperses more heat than ever before, and more venting near the SoloKon back brace and spider landing.
The distinctive cast-aluminum basket with spring-loaded terminals wraps around and protects these specialized inner workings, with the Solo-Baric crest branded into the back plate.
The Solo-Baric L7 remains available in 2-Ohm or 4-Ohm DVC and conducts business from a sealed or vented box application.
Endret av braendaas
NY PRIS!
