Killha Skrevet Mai 19, 2010 Rapporter Share Skrevet Mai 19, 2010 (endret) JL Audio 10w7 http://mobile.jlaudio.com/images/7594.jpg Free Air Resonance (Fs): 30.6 Hz Electrical “Q” (Qes): 0.578 Mechanical “Q” (Qms): 7.647 Total Speaker “Q” (Qts): 0.537 Equivalent Compliance (Vas): 1.28 cu. ft. / 36.1 liters One-Way, Linear Excursion (Xmax)*: 0.9 in. / 23 mm Reference Efficiency (no): 0.171% Efficiency (1W/1m)**: 84.3 dB SPL Effective Piston Area (Sd): 59.8 sq. in. / 0.0386 sq. m. DC Resistance (Re): 2.75 ohm Nominal Impedance (Znom): 3 ohm Thermal Power Handling (Pt): 750W Driver Displacement: 0.09 cu. ft. / 2.5 liters Net Weight: 30 lbs. / 13.6 kg Alpine MRD M1005 Details: * mono subwoofer car amplifier * 700 watts x 1 at 4 ohms (1000 watts RMS x 1 at 2 ohms) * internal, variable-speed cooling fan * STAR Topology for cleaner sound * Amp Link for single-cable hookup to compatible Alpine receivers (special cable required, not included) * Bass Engine® features: o low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope o selectable subsonic filter (off, 15Hz, or 30 Hz) o Bass EQ (0-16 dB at 45 Hz) * top-mounted digital control center with cover * CEA-2006 compliant * MOSFET power supply and output stages * preamp inputs and outputs * 4-gauge power and ground leads and 80 amp fuse recommended — wiring and hardware not included with amplifier * extra-large terminals * fuse rating: 20A x 4 * dimensions: 14-1/4"W x 2-1/2"H x 9-1/2"D Dette er i en dobbel kasse, så altså 2 x bassere og 2 x forsterkere. Ett reele selges også, sammen med Stinger SPV44, og div kabler, 2 kondensatorer på 1.00 F Dette veier såpass mye at jeg ikke sender det rundt i norge, så må enten hentes i drammen, eller så kan jeg komme med det til deg der du eventuelt bor, vis det ikke er så langt unna. De har blitt brukt jevnt, men aldri blitt pusha ordentlig. Pris: bud mellom 6-8 tusen.. email: jan.g.kielich@hotmail.com Endret Juni 2, 2010 av Killha Siter Lenke til kommentar Del på andre sider More sharing options...
