rustproblemer på mazda 6 2004?
MissDragonfly
  • 1 month later...
Hello Irmantas, I saw your ad by the way. :) Is it rusted a hole through the steel in the spare wheel well? And the wheel arches, are they rusted away or just a little outside?
Er det rustet hull tvers igjennom i reservehjulsbrønnen? Og hvordan er hjulbuene / skjermbuene? Er de rustne tvers igjennom eller bare utenpå?
http://www.google.com/search?&q=mazda+6+rust
http://forum.mazda6club.com/models-trim/186709-wheel-arches-beginning-rust-check-yours-now.html
http://mazda-ogn.org/phpBB3/viewtopic.php?p=94121&sid=13072dd556b0b9d4e12b38cb7bbb5baf
"de bekreftet forholdet som kjent i en periode, ble beskrevet som en ulykksalig leveranse av kitt til sveisefugene fra den onde stemora(Ford)."
http://www.bilforumet.no/mazda-6/217962-rustproblemer-mazda-3-6-nye-m6.html "Problemet til gamle M6 og 3éren var at det ikke er annet enn lakk i hjulbue kanten på disse bilene.."
Jeg har et par seksere i familien. Kanskje jeg burde følge opp de litt før de ruster vekk. ;)
Super Moderator
Hakkum
Hello, Skody, no it's not trough, rust is only on top, steel inside is good. Wheel brake disc was in rust too, but I change it. If you do not drive mazda for some time, rust is coming very fast on brake disc :) On arches rust is too only on top, rust on arches coming because before there was R17 225/45 rims, and when some one siting in a back seat, tyres damaging arches on fast driving.
What's happening when You place R17 225/45 rims on non sport mazda 6 (in this photo R16 195/55):
Mazda 6 arches is made from very bad material, inside of the arche is some material like wool,so that think all the time sucking water inside of him and making mazda 6 arches to get rusty very fast.
One more gift from mazda 6:
Endret av Irmantas
