2 EXTREME batterier! Banner Running Bull
Jeg kan på ingen måte begynne å skrive en god nok tekst som rettferdiggjør disse batteriene, så her lar jeg ekspertene ta til ordet, dessverre på engelsk, men håper det går bra!
The Running Bull is the number one solution wherever vehicles with special, additional consumers require large amounts of power over extended periods, e.g. premium class cars and taxis. As a result of innovative AGM* technology, the Running Bull contains no liquid electrolyte, which means that with this battery, Banner sets new benchmarks in relation to performance, safety and freedom from maintenance.
With the new Running Bull AGM battery, Banner has taken another step on the road to the battery future. The Running Bull, which does not contain liquid electrolyte, represents a new Banner benchmark with regard to safety, freedom of maintenance and performance.
The principle: The Running Bull, which in principle is a lead-acid battery, differs from its conventional counterparts in two decisive ways: • The electrolyte is absorbed into a non-woven web and consequently bounded. • The battery is sealed by a valve. The consequence of this innovative approach is that the battery contains no free, liquid electrolyte and therefore, acid cannot escape even if the casing is damaged. A further advantage of the AGM battery and its recombination technology is the fact that it is entirely sealed and absolute maintenance-free.
The technology: The gas generated during charging is conducted to the negative electrode through the pores of the glass fibre web, where it is recombined (reconstituted) to form water. This means that water losses are impossible under normal operating conditions. Moreover, the electrode plates are compacted to such as degree by the tight set installation that sludging is cut to a minimum. The result is a high level of cyclical resistance.
Langsiktig topp ytelse
Maksimal kapasitet
Optimal startkraft
Den nyeste AGM teknologien
Vibrasjonsmotstand
Lekkasjesikkert
Absolutt vedlikeholdsfritt
Ekstra lang levetid
Biler
Taxi
Traktor
Off-Road
Campingvogner
Motor båter
Lastebiler med 12v anlegg
12V 70 Ah 760A
LxBxH 27,8 x 17,5 x 19,0
Ny pris i butikken er 3346kr!
Selges her til sterk redusert pris!
Helt nye! Ved kjøp av begge batteriene kan vi forhandle litt om prisen!
Ta kontakt igjennom FINN annonse: http://www.finn.no/finn/torget/tilsalgs/annonse?finnkode=23163802
