vinkel på fremhjul når man drifter
ougkim
Originally posted by Skody
Hvis du tenkte på rattutslag så vil jeg tro at de ligger såpass bredt at de må svinge så mye... Forøvrig tipper jeg at all den positive camberen gjør at det blir/ser bredere ut?!
negative camberen;)
Camber Kits
Camber kits are pillow/ball mounts that replaces your stock shock mountings. it alows you to adjust the number of degrees of negative camber (top of the tire tipping inward) you have. More negative camber gives you more stability, because when the tire rolls over ( tips in, whatever) in the drift, it flattens out giving you a bigger contact patch to work with. (By the way this was written by Onicam and it was so precise a description I thought I would use it. Thanks Oni...)
Selvfølgelig mente jeg negativ! ;-)
Jeg bare levde i gamle dager. Sånn rundt 1967 *hosthost*
Forøvrig har jeg lest at det er "praktisk" med en pos/neg? vinkel på bakhjulene UTOVER slik at de "hjelper" ræva med å komme ut ...
Super Moderator
Hakkum
