Alpine, Phoenix Gold + + +
kimmen
Alpine CDA-9887R selges
high-end spiller med alt av nødvendige funksjoner. 3x 4v pre out, tidskomp, 2/3 veis aktiv deling, bluetooth+++
nypris 4698,-
2800,-
Phoenix gold Outlaw 1845 Limited Edition. no.1397/1500
begynner å bli rimelig sjelden her til lands i denne tilstanden. tør å gå så langt i å påstå den er som ny!
består av en m50 og en m100 i samme chassis.
M50 section:
2 x 50W @ 4 ohms (12.0V)
2 x 80W @ 4 ohms (13.8V)
2 x 100W @ 2 ohms (12.0V)
2 x 120W @ 2 ohms (13.8V)
1 x 245W @ 4 ohms bridged (13.8V)
Fuse: 15A (4 ohms) or 35A (2 ohms)
M100 section:
2 x 100W @ 4 ohms (12.0V)
2 x 185W @ 4 ohms (13.8V)
2 x 200W @ 2 ohms (12.0V)
2 x 230W @ 2 ohms (13.8V)
1 x 500W @ 4 ohms bridged (13.8V)
Fuse: 40A (4 ohms) or 70A (2 ohms)
THD at 4 ohms: 0.05%
S/N Ratio: >100dB
Dimensions: 29.25" x 11.63" x 2.0" (74.3cm x 29.6cm x 5.1cm)
må ikke selge den og har vel egentlig ikke lyst, men vet ikke om jeg gidder bygge noe bilstereo heller så denne ønsker jeg bud på.
2stk kinetik hc-600 bilstereo batterier som også skal bort. dem er heller ikke brukt. http://www.kinetikaudio.com/2009/product.asp?C=1&P=KHC600
nypris 1890,- pr stk.
selges 1100,- pr stk. evt 2000,- for begge.
2stk atomic quantum qt10d4 subwoofere. 10". 2x4ohm.
300w rms/600w peak
- Audiophile’s Sound Quality
- Cast Aluminum Basket
- Excellent for small sealed Enclosure.
- Capable of reproducing low
- Frequency down to 30Hz with accuracy.
* Rigid Die cast aluminum basket
* Organic long fiber non-pressed cone body for accurate tight bass
* Curvilinear Kevlar reinforced cone body
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity
* Butyl rubber surround heavy duty and forever lasting.
* Compressed mounting ring gasket
* vented coil for extra heat dissipation
* 2-1/2 inch high temp aluminum voice coil
* extended, machined cut one piece back plate
* Powerful 1 inch thick 90 oz high energy magnet
* 2-1/2 inch long excursion motor structure
* integrated heavy duty lead wire on spider prevent short circuit and melt down
* dome shape dust cap design
* low carbon front and back plate
* Vented magnetic gap technology
* Laser etched, machined and chromed back plate
http://www.atomicspeakers.com/quantum_10d.html
nypris 2290,- pr stk.
selges for 1400,- pr stk. billigere ved å kjøpe begge.
det er lov å komme med med saklige bud.
jobber en del så ikke alltid mulig ta tlf derfor svarer jeg også på sms.
link med bilder:
http://www.finn.no/finn/torget/tilsalgs/annonse?finnkode=25258266
