audi a3 - slette servicemelding?
koskinen
Fungerer på noen biler, du kan jo se om du lykkes ;)
Hold inne resettknappen for tripptelleren mens du skrur på tenningen (ikke start motoren). Ikke slipp resettknappen men fortsett å holde den inne. Trykk på den venstre knappen under turtelleren til serviceindikatoren endrer tekst. Slipp så begge knappene og indikatoren skal være resatt.
Administrator
Om det ikke fungerer kan du prøve dette:
1. Switch ignition off
2. Press and hold down reset button for trip odometer (2) in instrument cluster
3. Switch ignition on while button is pressed down. "Service OIL" appears in the display of the trip odometer (3)
4. Release button
5. Pull setting knob for time (1) in instrument cluster until "Service OIL" indication is reset. "- - -" appears in display (3).
6. Press reset button for trip odometer (2) again, to advance to next service event.
7. Release button.
8. "Service INSP" appears in display (3).
9. Pull setting knob for time -1- until "Service INSP" indication is reset.
10. "- - -" appears in display (3).
11. Switch ignition off.
Administrator
