Synkronisere nøkkel audi a6 c5
hanbe
Hei.
Er det noen som vet hvordan jeg kan synkronisere min fjern nøkkel med bilen min?
Har bla. Feilkode 00955. Med VCDS kan jeg ikke synkronisere nøkkelen, ross tech skriver at jeg må sjekke produsentens manual for prosedyre.
Noen så har en god prosedyre?
Jeg har 1 orginal nøkkel med fjernstyring og 1 verkstednøkkel.
Fjernstyringen fungerte fint, helt til jeg koplet vekk batteriet i kanskje 24 timer.
Dritten begynte å lage alarm midt på natten. Forstyrret nattesøvnen :(
Etter alarm nr 2 koplet jeg vekk batteriet.
Det er en 98 mod.
Har du lest DETTE.
Ja, det hjelper meg lite. Les nedenfor:
"If Adaptation Channel 21 is not available the control module does NOT support matching remotes with VCDS (or any scan tool). In those cases the remote matching procedure as per the Repair Manual and/or vehicle Owner's Manual will need to be completed. "
Programming new remote controls
Two keys and all the remote controls that are to be programmed
will be needed. The maximum number of remote controls that can be
programmed, including old and new, is four.
- Insert first key into ignition switch, and turn it to
"ignition on."
- Insert second key into outer door handle, and turn it to
unlocked position for 10 seconds.
System alarm will emit three beeps.
- Take first remote control to be programmed and press button
-1-, two beeps will be emitted. For second remote control, press
button -1-, two beeps will be emitted. Use same procedure to program
third or fourth remote control. All remote controls must be programmed
within one minute, otherwise new programming will cancel and old
remote control programming will be valid.
- Turn key in outer door handle to unlocked position for 10
seconds, one beep will be emitted.
- Switch ignition off.
Administrator
Ja, eg fant den tidligere med litt hjelp av google.
Men eg mista litt tiltro til den når eg til og med fant en annen:
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Eg gjekk ned igjen og prøvde atter ein gang den du sendte meg.
Problemet mitt ligger vel i at eg aldri hører noe av de 3 bipene.
Det kan være eg har 1 annen feil =/
Jeg har 00955 Adaptation Limit Surpassed
og etter en stund har jeg fått:
01559 - Drivers Door; 59-00 Can't Unlock
Den var ikke der med en gang. Dvs. etter fjerning av alle alarmer :)
Det som var mest håpløst med denne bilen var at jeg syns det er begrenset med informasjon om den. Har hatt/har både A3 og A4, begge hadde jeg Haynes bøker til og mye informasjon.
Angrer nå på at solgte A4'en :(
