Thomas80 Skrevet Februar 9, 2012 Rapporter Share Skrevet Februar 9, 2012 Hei Noen som veit tiltrekkninsmomentet på bankesensorene på en 90 mod audi 2,3 20v 7a motor? Siter Lenke til kommentar Del på andre sider More sharing options...
ZyNTeX Skrevet Februar 10, 2012 Rapporter Share Skrevet Februar 10, 2012 Heisann. Legger ut forskjellige momenter, mens jeg først er i gang ;) Momenter til Audi 5 Sylinder ABS wheel sensor 10 Nm Air mass sensor plenum 10 Nm Alternator adjustment locking nut 35 Nm Alternator adjustment - new belt 8 Nm Alternator adjustment - old belt 4 Nm Alternator pivot bolt 35 Nm Alternator strap pivot bolt 20 Nm Anti-roll bar link rod 20 Nm Anti-roll bar to subframe 35 Nm Ball joint clamp bolt 65 Nm Ball joint to wishbone 65 Nm Bearing to strut 50 Nm Big ends 50 Nm Brake carrier to front hub to 1986 115 Nm Brake carrier to front hub from 1986 125 Nm Brake carrier to rear hub 65 Nm Brake caliper to guide pins 35 Nm Brake caliper to carrier (Porsche Monobloc) 90 Nm Brake lines 15 Nm Brake pressure accumulator (WR) 45 Nm Brake servo to master cylinder 30 Nm Brake servo to motor carrier 20 Nm Cam bearing caps (10V) 20 Nm Cam bearing caps (20V) 15 Nm Cam belt cover 10 Nm Cam cover 10 Nm Cambelt backing plate to block 20 Nm Camshaft gear (10V) 80 Nm Camshaft gear (20V) 67 Nm Clutch master cylinder 20 Nm Clutch pressure plate 25 Nm Cold start valve 10 Nm Cylinder head bolts 40 Nm,60 Nm + 180° (90+90) Differential fill & drain plugs 25 Nm Downpipe to flange 25 Nm Downpipe to gearbox 30 Nm Downpipe to turbo 35 Nm Earth strap to motor carrier 20 Nm Engine mounting to body 40 Nm Engine to gearbox - M8 30 Nm Engine to gearbox - M10 45 Nm Engine to gearbox - M12 60 Nm Exhaust joints 25 Nm Exhaust manifold to head (10V) 35 Nm Exhaust manifold to head (20V) 25 Nm Flywheel bolts, locking 100 Nm Flywheel bolts, non-locking 75 Nm Flywheel cover 25 Nm Fuel pump check valve 20 Nm Fuel pump terminals 10 Nm Fuel reservoir (all) 10 Nm Gearbox carrier to mount 45 Nm Gearbox fill & drain plugs 25 Nm Halfshaft to gearbox (M8) 45 Nm Halfshaft to gearbox (M10) 80 Nm Halfshaft to hub 280 Nm Harmonic damper (pulley) 450 Nm Harmonic damper (pulley) using 2079 350 Nm Harmonic damper Allen screws (10V) 20 Nm Harmonic damper Allen screws (20V) 22 Nm Hydraulic pump - hose from reservoir 40 Nm Hydraulic pump - hose to brake accumulator 25 Nm Hydraulic pump - hose to steering rack 35 Nm Tandem hydraulic pump - piston cap 50 Nm Idler roller 10 Nm Inlet manifold to head (10V) 25 Nm Inlet manifold to head (20V) 22 Nm Intercooler to body - 6mm 10 Nm Intercooler to body - 8mm 20 Nm Knock sensor 20 Nm Lower flywheel cover 25 Nm Lower cambelt cover 10 Nm Main bearings 65 Nm Multi-way coolant junction to block 10 Nm Oil cooler to body 30 Nm Oil cooler line adapters to filter bracket 50 Nm Oil cooler lines to filter bracket adapters 35 Nm Oil drain plug 40 Nm Oil drain line to turbo (10V) 25 Nm Oil drain line to turbo (20V) 10 Nm Oil feed to turbo at filter bracket 10 Nm Oil feed line to turbo (10V) 25 Nm Oil feed line to turbo (20V) 10 Nm Oil filter bracket to block 70 Nm Oil filter 20 Nm Oil lines to oil cooler (10V) 35 Nm Oil iines to oil cooler (20V) 40 Nm Oil pick-up pipe 10 Nm Oil pressure relief & temperature sender 45 Nm Oil pressure sender 25 Nm Oil pressure sender adapter 50 Nm Oil pump retaining bolts 10 Nm Oil spray jets (bores) 10 Nm Pedal frame 25 Nm Propshaft carrier to body 20 Nm Propshaft to gearbox 55 Nm Propshaft to differential 55 Nm Rear crank oil seal housing 10 Nm Shock absorber retaining cap 180 Nm Spark plugs (MB) 20 Nm Spark Plugs (WR, WX, GV, RR) 30 Nm Starter to engine 60 Nm Steering rack to body 35 Nm Steering wheel 40 Nm Strut to body 60 Nm Subframe to body (10V) 35 Nm + 90° Subframe to body (20V) 65 Nm + 90° Sump bolts M6 - 10 Nm, M8 - 22 Nm Track rod carrier to rack 40 Nm Track rod end to strut (front) 50 Nm Track rod end to strut (rear) 60 Nm Track rod end to subframe (rear) 60 Nm Turbo to manifold 60 Nm Turbo water to multi-way 15 Nm Upper cam cover retainers 10 Nm Warm-up regulator to block 20 Nm Wastegate diaphragm nut 20 Nm Wastegate to downpipe 25 Nm Wastegate to manifold 25 Nm Water pump (10V) 20 Nm Water pump (20V) 22 Nm Wheel bolts 110 Nm Wishbone to subframe 60 Nm I ditt tilfelle så skal da bankesensor tightes med 20nm. Siter Audi 80q 2.3E (Sugetrimprosjekt) Ford Sierra 2.0 DOHC (Sugetrim) Volvo 460 2.0L (Vrak) Bmw E36 318i m/M3 Styling (Senere prosjekt) Audi 80 1.8s (Solgt) Lenke til kommentar Del på andre sider More sharing options...
Thomas80 Skrevet Februar 10, 2012 Forfatter Rapporter Share Skrevet Februar 10, 2012 Tusen takk :) Siter Lenke til kommentar Del på andre sider More sharing options...
ZyNTeX Skrevet Februar 10, 2012 Rapporter Share Skrevet Februar 10, 2012 Bare hyggelig ;) Skulle det være noe så veit du hvor vi er ;) Siter Audi 80q 2.3E (Sugetrimprosjekt) Ford Sierra 2.0 DOHC (Sugetrim) Volvo 460 2.0L (Vrak) Bmw E36 318i m/M3 Styling (Senere prosjekt) Audi 80 1.8s (Solgt) Lenke til kommentar Del på andre sider More sharing options...
