Bilen går kun i 1.gir. DSG
thaugv
Jeg har en 05, 2,0 med DSG kasse. Bilen virker kun i 1.gir forover. Ikke revers eller noen annen gir. Det lyser gult motorlys og indikatoren for hvilken gir den står i på dashbordet blinker. Hadde den på verksted for diagnose og følgende feilkode kom opp: 17100 (P0716) og 18148 (P1740)
Se også vedlegg.
Først kom vi frem til en eller annen sensor inni kassen som føler mot svinghjulet e.l var ødelagt. Jeg byttet denne, men det ble ikke bedre.
Noen som vet hva problemet er?
17100/P0716 - Transmission Input Speed Sensor (G182): Implausible Signal
Possible Symptoms
MIL on
Shifting issues
Possible Causes
Failed Transmission Input Speed Sensor (G182)
Poor electrical connections at wiring harness
Special Notes
When found on the 02E, see TSB 37-06-07 (TPI 2012681) for details. Se nederst
18148/P1740 Clutch temperature control faulty
TSB 37 06 07
Transmission, DSG, Intermittent Engagement Delay Upon Acceleration
Intermittent delay in power transfer upon acceleration. May be accompanied by a slight jerking sensation when pulling away on vehicles with DSG transmission.
Upon acceleration engine RPMs may reach between 2000 rpm and 4000 rpm before the vehicle will pull away. The complaint occurs mainly on warm engine.
Technical Background
Failure of the sensor for the transmission RPM input -G182- and for the clutch temperature sensor -G509-,caused by:
• Wiring harness connector not correctly slotted.
• Sensor faulty or wiring harness damage.
Either one of the fault entries may be logged in the fault memory:
17100 or P0716 Input Turbine/Speed Sensor (A) Circuit Range/Performance
18148 or P1740 Clutch Temperature Monitoring
Service
Note: It is not necessary to replace the Mechatronics Unit.
• Ensure that the wiring harness connector is fully seated and locked into
position, then recheck DTCs.
If DTCs are still present, further diagnosis is needed.
Check the wiring harness connector, terminal ends and harness routing
for transmission input RPM -G182- / clutch temperature sender -G509- .
If wiring harness connector, terminal ends and harness routing for
transmission input RPM -G182- / clutch temperature sender -G509- are
OK:
• Replace sensor -G182-
Administrator
Takk for svar, men ble litt for avansert for mitt lille, enkle hode...ett bilde sier mer enn 1000ord...
Jeg bytta motor/ gir for litt siden, og bilen gikk fint ca 10mil. Plutselig var det stopp... Jeg har gamlekassa stående, så jeg vurderer å bytte tilbake dersom det hjelper. Litt arbeid,men...
17100 Gearbox input speed sender -G182, implausible signal
Fault causes:
I Gearbox input speed sender -G182 defective
I Excessive engine speed detected (engine over-revving, sender wheel defective)
Fault detection:
I In the control unit a gearbox input speed above a preset threshold was detected
Remedy:
Check measured value block 007 in gearbox control unit (compare engine speed and gearbox input speed)
Replace gearbox control unit only if all above fault sources can be excluded or have been checked
Antar begge giverene sitter inni kassen men er ikke sikker.
Administrator
