Selges: 2stk Kenwood KFCW3013 12" subber i lukka kasse
ftpfloppy
2stk Kenwood KFCW3013 12" subber i lukka kasse selges! 400rms! Selges for 1500kr før helja!
http://www.finn.no/finn/torget/tilsalgs/bilder?finnkode=33976110
[ATTACH]29287[/ATTACH]
Spesifikasjoner:
300mm P.P.Cone with fiber texture
Diamond Array Diaphragm
1200W Maximum Input Power
Dual Ventilation System
Rubber surround
Push Terminals
Reversible gasket
Høyttaler:
Speaker Type: Subwoofer
Peak Input Power 1200W
Rated Input Power 400W
Speaker Size 300mm
Speaker Cone Design Diamond-Array pattern
Magnet Type Ferrit
Terminals Silver-plated Push Type
Dual Ventilation System Yes
Speaker cover Yes, as part of dual ventilation system
Gasket Installation two-sided
Installation Capabillity Sealed/ Ported
Høyttalerspesifikasjoner:
Maximum Input Power 800W
Woofer Cone material Injection P.P. Cone
Speaker Basket Steel
Speaker Surround Rubber
Sensitivity 85dB/W/m
Frequency Response 34Hz ~ 300Hz
Subwoofer Impedance 4Ω x 1
Dimensions (W x H x D) 326 x 326 x 170.5mm
Mounting Depth 153mm
Mouting Hole Diameter Ø 282mm
Speaker Weight 6300gr
Weight of Magnet 1780gr
Subwoofer Parameters:
Nominal impedance (Z) 4Ω
DC resistance (Re) 3.4Ω
Resonant frequency (FSO) 25Hz
Mechanical Q factor (QMS) 8.25
Electrical Q factor (QES) 0.91
Total Q factor (QTS) 0.82
Voice coil inductance (LBM) 1.65mH
Voice coil diameter (d) 65mm
Force factor (BL) 10.5T/m
Peak excursion Xmax 15.1mm
Moving mass (MMS) 183gr.
Volume accoustic compliance (VAS) 83.7liter
Piston Area (SD) 0.051m²
Displacement 2155cc
Sealed box volume 35.4liter
Sealed Box Dimensions 475 x 362 x 299mm ( 19mm thick MDF)(WxHxD)
Vented box volume 56.6liter
Vented Box Dimensions 590 x 362 x 355mm ( 19mm thick MDF)(WxHxD)
Port dimensions (labyrinth) (W x H x L) 38 x 324 x 546mm
