Selges: Cadence 2x12" basskasse + Cadence 5kanals forsterker + JVC bilstereo
Cathriine
Etter at hyundai'n måtte gi slipp på livet, har jeg ikke lenger bruk for basskassen og forsterkeren. Selger også bilstereoen. Tenkte kanskje at noen her var interessert? :)
BILSTEREO[ATTACH]29641[/ATTACH]
JVC bilstereo KD-DB42E, Innebygget DAB/FM RDS HS-Ivi Tuner, AUX + USB-inngang, 2.5V Linjeutgang m/high-pass filter til Subwoofer/sluttrinn
CADENCE 2x12" - FXWB1222 [ATTACH]29642[/ATTACH]
350 watts rms power x2
700 watts peak power x2FX500
2x2 0hm Impendance
CADENCE FX500 - 5 KANALSFORSTERKER[ATTACH]29643[/ATTACH]
Cadence FX Series 5 Channel Amplifier
4 Ohm Power: 100 Watts RMS x 4ch
2 Ohm Power: 150 Watts RMS x 4ch
4 Ohm Mono: 300 Watts RMS x 1ch
2 Ohm Mono: 500 Watts RMS x 1ch
* High-Speed Mosfet Power supply
* Studio-Grade Bipolar Output Stage Transistors
* Full IC-Controlled Protection Circuitry
* Gold-Plated RCA Cable
* Frequency Response: 20Hz-30kHz
* Signal/Noise Ratio: >100dB
* Damping Factor: >200 @ 100Hz
* Minimum THD: <0.05%
* Channel Separation: >65dB
* Dimension: 18.2" x 11.0" x 2.75"(LxWxH)
Endret av Cathriine
Lagt inn bilder.
