henriks Skrevet Mai 6, 2012 Rapporter Share Skrevet Mai 6, 2012 selger noen 10w led arbeidslys LEDs: High power 10W CREE LED Power : 10W Lumen: 950Lumen Amps: Low amp draw IP Rate : IP68 Beam Pattern: Euro Vibration: 8Grms 24-2000Hz Voltage range: DC 9v-30v , (12v ,24v is available) Color temp: Available 6000k-7000K LED lifetime: 50000 hours Operating Temp: -40--- +105, Efficient heat dissipation Material: Hi-Impact aluminum alloy housing and stainless mounting hardware, Mounting system within the extrusion Package : 1pcs/inner white box. [ATTACH]30325[/ATTACH][ATTACH]30326[/ATTACH][ATTACH]30327[/ATTACH][ATTACH]30328[/ATTACH] lampene kan kobles sammen med braketter som følger med. selges 500kr stk. Siter Lenke til kommentar Del på andre sider More sharing options...
