SELGES: 12" Infinity sub i kasse m/JBL forsterker
  • 4 weeks later...
Hei! Beklager sent svar, har ikke vært her inne på en stund og så ikke at du svarte. På elementet står det 300w RMS, 1200w peak.
Fant dette om forsterkeren: (JBL P80.4)
SPECIFICATIONS:
Output 4 Ohms: 40W x 4
Output 2 Ohms: 80W x 4
Output 4 Ohms Bridged: 160W x 2
Signal-to-Noise Ratio: >110
Frequency Response ( ± 3 dB ): 10Hz - 50kHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 250mV - 4V
Variable 12dB electronic crossover allows the P-80.4 to be configured for a variety of applications
The four channels of the P-80.4 can also be configured into three channels or even two channels - this allows for increased expansion capabilities and system flexibility
"Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
Die-cast chassis uses entire amplifier footprint for cooling - and it looks awesome
High-output MOSFET power-supply topology doubles power into 2 ohms
quattroholic!
