Kjell Henning R Skrevet Oktober 18, 2012 Rapporter Share Skrevet Oktober 18, 2012 (endret) Siden bilforumet ser ut til å logge en Av automatisk etter en stund og etter å ha brukt tid på å skrive inn ett innlegg som forsvinner når jeg trykker legg inn ,med beskjed om att jeg ikke er innlogget ,så legger jeg ut spørsmålet mitt på Engelsk copy/paste. Blir rotete dette her men viss veivaksel føleren/sensoren ikke virker,vil da bensin pumpen gå? Viss denne sensoren ikke registrer rpm så vil ECU tro motoren står i ro mens en egentlig kikker på starteren. My Opel astra G 1.6 exel would not start. Previous owner have had problems that engine stop during high torque and also experienced starting problems now and then,at the end the engine would not start att all. Diagnos test were carried out,fault code on starting block were logged,immobilizer? They did not pay attention to this code since the engine were working ok at that time. After the engine would not start at all owner changed fuel pump and filter,also coil pack were changed.still no fun. I towed the car home and are doing some faultfinding .I hear the fuel pump relay click but no sound from fuel pump. Engine crank ower as it should.No start using start spray. yesterday I noticed that that the orange panel light engine "symbols" are not lite when ignition turned on.could it be that this light are missing if the ECU is "brain dead"? Are there any other fuses *that fuse 32 that are connected to the ignition system,relay,fuse...etc..? When start block is active,do this system block fuel supply and ignition spark? Ps.I hva not checked the crankshaft sensor yet. Br kjell Sendt fra min iPad Endret Oktober 18, 2012 av Kjell Henning R Siter Lenke til kommentar Del på andre sider More sharing options...
