Audi Coupe B4 2.6 v6 (VAG Fault Code 00575) LØST
TomLura
Hei sliter litt med dårlig effekt og bunndrag turtallet synker litt før det stiger igjen!
Har netopp hatt dashbordet ute for å bytte radiator i varme apparatet.
Er det noen vakum slanger som går fra motor og inn i bilen?
Noen som vett hvor N75 ventil befinner seg?
Fant dette:
00575 - Intake Manifold Pressure: Control Limit Not Reached
Possible Symptoms
  • Sudden complete loss of Power
  • Reduced Power
Possible Causes
  • Hoses incorrect connected, disconnected, blocked or leaking
  • Pressure Unit for Turbo Charger defective
  • Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
  • Check Hoses
  • Check Pressure Unit for Turbo Charger
  • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check Basic Setting > MVB 011
00575 - Intake Manifold Pressure: Control Limit Exceeded Possible Symptoms
  • Reduced Power
  • Charge Pressure too High
Possible Causes
  • Turbo Charger defective
Possible Solutions
00575 - Intake Manifold Pressure: Control Difference Possible Symptoms
  • Reduced Power
Possible Causes
  • In 1Z/AHU engines, stuck/rusted wastegate or actuator.
Possible Solutions
  • Check Hoses
  • In 1Z/AHU engines, clean rust scale off wastegate/actuator to allow lever to move.
vw golf 1 cab 1.8 gti 1987
Audi coupe 2.6 v6 1994
