Turtall henger
audi a3
Jeg har en audi a3 1,8tsq 2001 mod. Når jeg drar ut gira til ca 5000 omregninger så henger den igjen noe veldig, det skjer det samme i alle gira.. Har bytta den motor clutch føleren eller hva den heter. Er elektrisk gass på den så er ikke waier. Noen forslag til hva det kan være?
http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_%28TBA%29
Drive-by-Wire (DBW) Engines using KW-1281
(These are engines WITHOUT a physical cable between the accelerator and the throttle. Check to see if the engine speaks KW-1281 by looking in the top left of the Open Controller Screen Some examples of KW-1281 engine controllers are 2000+ Golf/GTI/Jetta/New Beetle/Audi TT 1.8T)
Turn the key on but do not start the car.
  • [select]
  • [01 - Engine]
  • [Measuring Blocks - 08]
Enter Group 060
  • [Go!]
  • [switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
  • [switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Drive-by-Wire (DBW) Engines using KWP-2000 or CAN
(These are engines WITHOUT a physical cable between the accelerator and the throttle. Check to see if the engine speaks KWP-2000 or CAN by looking in the top left of the Open Controller Screen. An example of a KWP-2000 engine controller is the 2002+ B6 Audi A4 1.8T. Some examples of CAN engine controllers are the Mk5 Golf 2.0T FSI)
  • [select]
  • [01 - Engine]
  • [basic Settings - 04]
  • Group 060
  • [Go!]
It should say "Basic Settings: OFF" on the top of your screen.
  • Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
  • Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
  • Click the [Done, Go Back] button and you're all set.
Administrator
