Feilkoder Passat 1.9 TDI 1998mod
Blanklaks
På de siste feilsjekkene nå så kommer det ikke opp noe på LMM. Har ikke funnet ut hva som gjorde det, bare sjekket kontakter og leet på ledninger.
VCDS-Lite
Det eneste jeg finner er denne, den reagerer i vertfall på LMM
Her er en liten logg
Sunday,11,May,2014,16:31:28
038 906 018 P,, 1.9l R4 EDC   00SG  1629,
,Group A:,'010,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Mass Air / Rev.,Absolute Pres.,Absolute Pres.,Load,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, mg/str, mbar, mbar,%,STAMP,,,,,STAMP,,,,
,0.01,425.0,969.0,989.4,0.0,,,,,,,,,,
,0.40,435.0,969.0,989.4,0.0,,,,,,,,,,
,0.78,445.0,969.0,989.4,0.0,,,,,,,,,,
,1.18,440.0,969.0,989.4,0.0,,,,,,,,,,
,1.58,445.0,969.0,989.4,0.0,,,,,,,,,,
,1.98,440.0,969.0,989.4,0.0,,,,,,,,,,
,2.38,435.0,969.0,989.4,0.0,,,,,,,,,,
,2.78,440.0,969.0,989.4,0.0,,,,,,,,,,
,3.18,440.0,969.0,989.4,0.0,,,,,,,,,,
,3.58,440.0,969.0,989.4,0.0,,,,,,,,,,
,3.97,440.0,969.0,989.4,0.0,,,,,,,,,,
,4.37,440.0,969.0,989.4,0.0,,,,,,,,,,
,4.77,440.0,969.0,989.4,0.0,,,,,,,,,,
,5.15,435.0,969.0,989.4,0.0,,,,,,,,,,
,5.55,425.0,969.0,989.4,0.0,,,,,,,,,,
,5.95,440.0,969.0,989.4,0.0,,,,,,,,,,
,6.35,430.0,969.0,989.4,0.0,,,,,,,,,,
,6.75,440.0,969.0,989.4,0.0,,,,,,,,,,
,7.13,440.0,969.0,989.4,0.0,,,,,,,,,,
,7.53,435.0,969.0,989.4,0.0,,,,,,,,,,
,7.93,430.0,969.0,989.4,0.0,,,,,,,,,,
,8.32,435.0,969.0,989.4,0.0,,,,,,,,,,
,8.72,435.0,969.0,989.4,0.0,,,,,,,,,,
,9.12,435.0,969.0,989.4,0.0,,,,,,,,,,
,9.50,435.0,969.0,989.4,0.0,,,,,,,,,,
,9.90,435.0,969.0,989.4,0.0,,,,,,,,,,
,10.29,435.0,969.0,989.4,0.0,,,,,,,,,,
,10.69,430.0,969.0,989.4,0.0,,,,,,,,,,
,11.09,435.0,969.0,989.4,0.0,,,,,,,,,,
,11.47,430.0,969.0,989.4,0.0,,,,,,,,,,
,11.87,450.0,969.0,989.4,0.0,,,,,,,,,,
,12.27,425.0,969.0,989.4,0.0,,,,,,,,,,
,12.65,430.0,969.0,989.4,0.0,,,,,,,,,,
,13.05,435.0,969.0,989.4,0.0,,,,,,,,,,
,13.44,440.0,969.0,989.4,0.0,,,,,,,,,,
,13.84,420.0,969.0,989.4,0.0,,,,,,,,,,
,14.24,430.0,969.0,989.4,0.0,,,,,,,,,,
,14.62,435.0,969.0,989.4,0.0,,,,,,,,,,
,15.02,430.0,969.0,989.4,0.0,,,,,,,,,,
,15.42,420.0,969.0,989.4,0.0,,,,,,,,,,
,15.82,430.0,969.0,989.4,0.0,,,,,,,,,,
,16.22,440.0,969.0,989.4,0.0,,,,,,,,,,
,16.62,425.0,969.0,989.4,0.0,,,,,,,,,,
,17.02,435.0,969.0,989.4,0.0,,,,,,,,,,
,17.42,435.0,969.0,989.4,0.0,,,,,,,,,,
,17.80,435.0,969.0,989.4,0.0,,,,,,,,,,
,18.20,425.0,969.0,989.4,0.0,,,,,,,,,,
,18.60,430.0,969.0,989.4,0.0,,,,,,,,,,
,18.99,440.0,969.0,989.4,0.0,,,,,,,,,,
,19.39,440.0,969.0,989.4,0.0,,,,,,,,,,
,19.79,445.0,969.0,989.4,0.0,,,,,,,,,,
,20.19,435.0,969.0,989.4,0.0,,,,,,,,,,
,20.59,435.0,969.0,989.4,0.0,,,,,,,,,,
,20.97,430.0,969.0,989.4,0.0,,,,,,,,,,
,21.37,440.0,969.0,989.4,0.0,,,,,,,,,,
,21.77,445.0,969.0,989.4,0.0,,,,,,,,,,
,22.15,440.0,969.0,989.4,0.0,,,,,,,,,,
,22.55,445.0,969.0,989.4,0.0,,,,,,,,,,
,22.95,445.0,969.0,989.4,0.0,,,,,,,,,,
,23.35,440.0,969.0,989.4,0.0,,,,,,,,,,
,23.75,440.0,969.0,989.4,0.0,,,,,,,,,,
,24.14,440.0,969.0,989.4,0.0,,,,,,,,,,
,24.54,435.0,969.0,989.4,0.0,,,,,,,,,,
,24.94,435.0,969.0,989.4,0.0,,,,,,,,,,
,25.32,435.0,969.0,989.4,0.0,,,,,,,,,,
,25.72,435.0,969.0,989.4,0.0,,,,,,,,,,
,26.12,430.0,969.0,989.4,0.0,,,,,,,,,,
,26.51,430.0,969.0,989.4,0.0,,,,,,,,,,
,26.91,440.0,969.0,989.4,0.0,,,,,,,,,,
,27.31,440.0,969.0,989.4,0.0,,,,,,,,,,
,27.71,440.0,969.0,989.4,0.0,,,,,,,,,,
,28.11,445.0,969.0,989.4,0.0,,,,,,,,,,
,28.49,440.0,969.0,989.4,0.0,,,,,,,,,,
,28.89,435.0,969.0,989.4,0.0,,,,,,,,,,
,29.29,430.0,969.0,989.4,0.0,,,,,,,,,,
,29.67,450.0,969.0,989.4,0.0,,,,,,,,,,
,30.07,430.0,969.0,989.4,0.0,,,,,,,,,,
,30.47,435.0,969.0,989.4,0.0,,,,,,,,,,
,30.87,435.0,969.0,989.4,0.0,,,,,,,,,,
,31.27,440.0,969.0,989.4,0.0,,,,,,,,,,
,31.66,435.0,969.0,989.4,0.0,,,,,,,,,,
,32.06,430.0,969.0,989.4,0.0,,,,,,,,,,
,32.46,440.0,969.0,989.4,0.0,,,,,,,,,,
,32.84,435.0,969.0,989.4,0.0,,,,,,,,,,
,33.24,425.0,969.0,989.4,0.0,,,,,,,,,,
,33.64,440.0,969.0,989.4,0.0,,,,,,,,,,
,34.04,425.0,969.0,989.4,0.0,,,,,,,,,,
,34.44,440.0,969.0,989.4,0.0,,,,,,,,,,
,34.82,435.0,969.0,989.4,0.0,,,,,,,,,,
,35.22,440.0,969.0,989.4,0.0,,,,,,,,,,
,35.62,440.0,969.0,989.4,0.0,,,,,,,,,,
,36.01,430.0,969.0,989.4,0.0,,,,,,,,,,
,36.41,435.0,969.0,989.4,0.0,,,,,,,,,,
,36.81,430.0,969.0,989.4,0.0,,,,,,,,,,
,37.21,440.0,969.0,989.4,0.0,,,,,,,,,,
Så nå er bilen frisk?
Ble mye bedre går lettere og bruker mindre disel, men har fortsatt den voldsomme buldringa i eksosanlegget når jeg gir full gass og da ryker det svart.
Om det er normalt eller ikke vet jeg ikke, har lite greie på diselbiler.
Var ute å kjørte en tur i kveld og testet litt, lå på rundt 2000 omdreininger på 5 gir og ga full gass da kom buldringa med en gang og dårlig akselerasjon.
Tar jeg det roligere med gassen så går den bedre. Slipper jeg den ned i 50-60 km på 5 gir og gir full gass så er det ikke noe bråk å høre.
Har også et annet problem, det har vært der siden jeg kjøpte bilen.
Når den går så lett at den hverken drar eller butter i mot så lugger den noe forferdelig, så fort jeg gir litt gass eller slipper opp gassen så blir det borte.
Har spurt mange om hva det kan være men ingen som har noe løsning på det.
Har sett litt på wastegate staget.
Klarer ikke å presse det oppover med fingrene, setter jeg på en skrutrekker så får jeg presset det opp. Virker som det er ei veldig stri fjær på den akslingen som går inn i turboen.
Starter jeg bilen og lar den gå på tomgang så får jeg ikke presset opp staget til wastergate i det hele tatt.
Noen som vet om dette er riktig.
  • 4 weeks later...
