Feilkoder A4 B8
Blaxtah
Hei!
Lurte på om noen kunne hjelpe meg med noen feilkoder jeg har.
Lurer på hva alle betyr, og hva som må kjøpes/byttes.
Bilen er en 2009 mod A4 Avant, 2.0 TDI 143hk
De 4 første er vel glødepluggene som bør byttes.
Chassis Type: 8K (8T0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 52 53 55 56 62
          69 72
VIN: X   Mileage: 107280km-66660miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 B    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 6270
   Revision: --H01---
   Coding: 0104002C18072820
   Shop #: WSC 56847 000 1048576
   ASAM Dataset: EV_ECM20TDI03L906022B A01016
   ROD: EV_ECM20TDI03L906022B.rod
   VCID: 244C16B32F9BAC012B3-8071
4 Faults Found:
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [109] - Electrical Fault
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 105878 km
                    Date: 2015.01.10
                    Time: 13:37:38
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [109] - Electrical Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 105878 km
                    Date: 2015.01.10
                    Time: 13:37:38
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [109] - Electrical Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 105878 km
                    Date: 2015.01.10
                    Time: 13:37:38
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [109] - Electrical Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 105878 km
                    Date: 2015.01.10
                    Time: 13:37:38
Readiness: 0 0 0 0 0
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
   Component: BCM2 1.1      H71 0134
   Revision: 00002001
   Coding: 070200
   Shop #: WSC 06335 000 00000
   VCID: 72E020EBADEF72B169F-8027
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: ELVAUDIB8  H35 0039
4 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 40
                    Reset counter: 34
                    Mileage: 105839 km
                    Time Indication: 0
                    Date: 2015.01.09
                    Time: 14:27:18
00192 - Rear Left Door Handle Touch Sensor (G417)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 74
                    Mileage: 106958 km
                    Time Indication: 0
                    Date: 2015.01.15
                    Time: 14:45:50
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 34
                    Mileage: 107266 km
                    Time Indication: 0
                    Date: 2015.01.21
                    Time: 10:54:32
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 34
                    Mileage: 107282 km
                    Time Indication: 0
                    Date: 2015.01.26
                    Time: 17:13:17
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0105.05.080794
   Coding: 34000000
1 Fault Found:
03220 - Stop Valve for Coolant for Climatronic (N422)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 105839 km
                    Time Indication: 0
                    Date: 2015.01.09
                    Time: 14:17:12
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0110740778
   Coding: 01000E2000310441012002
   Shop #: WSC 06335 123 12345
2 Faults Found:
02615 - Fuel Tank Cap; Lock
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 30
                    Mileage: 105839 km
                    Time Indication: 0
                    Date: 2015.01.09
                    Time: 14:24:33
02616 - Fuel Tank Cap; Unlock
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 25
                    Mileage: 105839 km
                    Time Indication: 0
                    Date: 2015.01.09
                    Time: 14:24:38
Jeg nekter å tro at det er feil på alt her. Slett alle feilkoder å kjør noen dager å les av igjen.
Alle feilene du lister opp her har dukket opp ila. 2 uker, å de fleste av de den 09.01/15 og 10.01/15.
Alle glødepluggene er oppført med feil, samtidig. De 3 nederste er også kommet meget tett, under 10min mellom de.
Her lukter det ECU problemer eller fuktighet/vann/is i en eller flere kontakter.
Super Moderator
