OBDII eller OBDI?
vranglåsen
Du har obe2 på din bil du?
Pin Signal Beskrivelse 2 J1850 Buss +   3     4 CGND Chassis bakken 5 SGND Signal bakken 6 CAN High? J-2284 7 K-LINE (ISO 9141-2 og ISO / DIS 14230-4) 10 J1850 Bus-   11 Bruk ikke   14 CAN lav? J-2284 15 ISO 9141-2 L-LINE (ISO 9141-2 og ISO / DIS 14230-4) 16 + 12v Batteristrøm
Volkswagen OBD-2 kompatibilitetslisten
Modell Motor År (fra) OBD-2 Protocol Volkswagen Amarok 2.0 TDi, Diesel (163HP) 2010 KAN 11bit (500 kbps) Volkswagen Beetle   2000 ISO 14230-4, ISO 9141-2 Volkswagen Bora   1999 ISO 14230-4, ISO 9141-2 Bensin (100 HK) 1999 KW 1281 1.9 TDI-PD AJM, Diesel (114 HK) 1999 ISO 9141-2 2.0 Highline, Bensin (114 HK) 1999 KW 1281 V5, Bensin (148 HK) 1999 KW 1281 Bensin (114 HK) 2000 - Diesel (135 HK) 2001 ISO 9141-2 Diesel (129 HK) 2001 KW 1281 1J2, Bensin (168 HK) 2001 KW 1281 1.9 tdi, Diesel (100 hk) 2001 ISO 9141 1.9 tdi, Diesel (115HP) 2001 ISO 9141 1.6, Bensin (105HP) 2002 ISO 9141 Volkswagen Bora Variant Bensin (100 HK) 1999 KW 1281 Volkswagen Caddy 1.9 AEY, Diesel (64 HK) 1995 KW 1281 Bensin (60 hk) 1998 KW 1281 2.0 SDI, Diesel (70HP) 2004 KAN 11bit (500 kbps) 1.9 tdi, Diesel (105HP) 2006 KAN 11bit (500 kbps) 1.9 TDi, Diesel (105HP) 2008 KWP SLOW 2.0 TDi, Diesel (105HP) 2010 KAN 11bit (500 kbps) Volkswagen Caddy famely 1.6, Bensin (102 HK) 2007   Volkswagen Caddy Livet Diesel (74 HK) 2006   Volkswagen California 2.5 TDi, Diesel (130 hk) 2007 KWP SLOW Volkswagen Caravelle Bensin (109 HK) 1997   Diesel (86 HK) 1999 KW 1281 Volkswagen Corrado Bensin (188 HK) 1992 KW 1281 Bensin (135 HK) 1993 KW 1281 Bensin (114 HK) 1994   Volkswagen Crafter 2.5 DTI, Diesel (136HP) 2007 KAN 11bit (500 kbps) 2,5, Diesel (109HP) 2008 KAN 11bit (500 kbps) Volkswagen Eos 2.0 tdi, Diesel (140hp) 2006 KAN 11bit (500 kbps) 2.0 FSI, Bensin (150HK) 2006 KWP SLOW Volkswagen Eurovan Camper 1997 ISO 14230-4, ISO 9141-2 Volkswagen Fox Bensin (74 hk) 2005   Bensin (74 hk) 2005 ISO 9141-2 Diesel (90 HK) 2005 ISO 14230-4, ISO 9141-2 Bensin (74 hk) 2005   Bensin (54 hk) 2005 ISO 9141-2 Volkswagen FSI Bensin (114 HK) 2008 ISO 9141-2 Volkswagen Golf Bensin (94 hk) 1993   Bensin (89 hk) 1994   1HX0, Bensin (60 HK) 1994 KW 1281   1997 ISO 14230-4, ISO 9141-2   1998 ISO 14230-4, ISO 9141-2 1.6 16V, Bensin (104 HK) 2000 ISO 9141-2 1.8T GTI (AGU), Bensin (148 HK) 2000 KW 1281 TDI, Diesel (121 HK) 2000     2001 ISO 14230-4, ISO 9141-2 TDI, Diesel (175 HK) 2002   Diesel (74 HK) 2005 ISO 9141-2 2.0 TDI, Diesel (139 HK) 2008 CAN Volkswagen Golf 3 1.9TDI 1Z, Diesel (89 HK) 1992 KW 1281 Bensin (74 hk) 1994   Bensin (60 hk) 1994 KW 1281 Bensin (89 hk) 1994   TDI 1Z, Diesel (89 HK) 1994 KW 1281 Diesel (64 HK) 1995   Bensin (74 hk) 1995 KW 1281 Bensin (89 hk) 1995 KW 1281 Bensin (89 hk) 1995 KW 1281 Bensin (74 hk) 1995 KW 1281 (Typ 1 H), bensin (74 hk) 1995   1.6 (AEA), bensin (74 hk) 1995   1.9 SDI, Diesel (64 HK) 1995 KW 1281 1HX0, Bensin (60 HK) 1995 KW 1281 1HX0 AEX 1.4L, Bensin (60 HK) 1995 KW 2000 VAG Bensin (114 HK) 1997   Bensin (100 HK) 1997 KW 1281 Bensin (116 HK) 1997 KW 1281 Bensin (100 HK) 1997 KW 1281 Bensin (74 hk) 1997 KW 1281 Diesel (89 HK) 1997 KW 1281 Bensin (89 hk) 1997 KW 1281 1.8L AAM, Bensin (74 HK) 1997 KW 1281 1.9TDI AFN, Diesel (109 HK) 1997 KW 1281 1.9 TDi, Diesel (110HP) 1997 ISO 9141 Diesel (89 HK) 1998 KW 1281 2, Bensin (115HP) 1998 KWP FAST 1.9 TDi, Diesel (90 hk) 2000 KWP FAST 1.9 tdi, Diesel (135HP) 2002 ISO 9141 1.9 TDi, Diesel (150HK) 2003 ISO 9141 Volkswagen Golf 3 Cabrio TDI, Diesel (89 HK) 1995 KW 1281 Bensin (89 hk) 1996 KW 1281 1,6 AFT, Bensin (100 HK) 1998 KW 1281 Volkswagen Golf 3 GL Bensin (89 hk) 1991 KW 1281 Volkswagen Golf 3 GL Mexico Bensin (89 hk) 1995 KW 1281 Volkswagen Golf 3 GT Bensin (100 HK) 1995 KW 1281 Volkswagen Golf 3 GTI 16V, Bensin (148 HK) 1995 KW 1281 8V, Bensin (114 HK) 1995   Volkswagen Golf 3 Variant Bensin (89 hk) 1995 KW 1281 Bensin (89 hk) 1995 KW 1281 Bensin (89 hk) 1995 KW 1281 Diesel (89 HK) 1997   Bensin (100 HK) 1997 KW 1281 Bensin (100 HK) 1998 KW 1281 TDI, Diesel (89 HK) 1998 - TDI, Diesel (89 HK) 1998 KW 1281 Bensin (74 hk) 1995 KW 1281 Volkswagen Golf 4 Bensin (74 hk) 1997 KW 1281 Bensin (100 HK) 1998 ISO 9141-2 1,4 16v, Bensin (74 HK) 1998 ISO 9141-2 Bensin (124 HK) 1999   Bensin (100 HK) 1999 KW 1281 1.8, Bensin (124 HK) 1999 KW 1281 1.9 TDi, Diesel (110HP) 1999 ISO 9141 Bensin (104 HK) 2000   1.9 TDi, Diesel (115HP) 2000 ISO 9141 Diesel (100 HK) 2001   Diesel (136 HK) 2001 ISO 14230-4 1.4 16S, Bensin (75hp) 2001 ISO 9141 1.9 TDi, Diesel (90 hk) 2001 ISO 9141 Bensin (148 HK) 2002 KW 1281 1.4 16s, Bensin (75hp) 2002 ISO 9141 1.6 16V, Bensin (105HP) 2002 ISO 9141 Bensin (74 hk) 2003 KW 1281 TDI Variant, Diesel (100 HK) 2003 ISO 9141-2 1.9 TDi, Diesel (101HP) 2003 ISO 9141 1.9 tdi, Diesel (130 hk) 2003 ISO 9141 1.9 TDi, Diesel (90 hk) 2006 KWP SLOW 1.9 TDi, Diesel (105HP) 2006 KWP SLOW Variant 1,6 16V Motor AZD, Bensin (104 HK) 2001 KW 1281 Volkswagen Golf 4 Variant Bensin (100 HK) 2001 ISO 9141-2 TDI, Diesel (129 HK) 2001 KW 1281 TDI, Diesel (100 HK) 2005 KW 1281 Bensin (100 HK) 2005 KW 1281 Volkswagen Golf 5 Diesel (104 HK) 2004   1.9 tdi, Diesel (105HP) 2004 KWP SLOW 1.6 FSI, Bensin (115HP) 2004 KWP SLOW 2.0 TDi, Diesel (140hp) 2004 KAN 11bit (500 kbps) 2.0 FSI, Bensin (200HP) 2005 KWP SLOW 2.0 TDi, Diesel (170HP) 2008 KAN 11bit (500 kbps) Volkswagen Golf 6 2.0 TDI, Diesel (110HP) 2009 KAN 11bit (500 kbps) 1.6 TDi, Diesel (105HP) 2010 KAN 11bit (500 kbps) 1.4 TSI, Bensin (122HP) 2011 KAN 11bit (500 kbps) Volkswagen Golf GL   1996 ISO 14230-4, ISO 9141-2 Volkswagen Golf GTI Bensin (148 HK) 1998 KW 1281 Volkswagen Golf 5 Bensin (101 HK) 2005 ISO 14230-4, ISO 9141-2 1,6l, Bensin (101 HK) 2006   TSI, Bensin (139 HK) 2006 CAN TSI, Bensin (139 HK) 2006 CAN TSI, Bensin (139 HK) 2006 CAN Volkswagen Golf 5 Variant Diesel (104 HK) 2008 KW 1281 Volkswagen Golf 6 Diesel (109 HK) 2008 CAN FSI, Bensin (121 HK) 2008 CAN Bensin (80 hk) 2009 KW 2000 VAG 1.2, Bensin (80 HK) 2009 KW 2000 VAG Volkswagen Golf VR6 Bensin (172 HK) 1995   Volkswagen Jetta   1997 ISO 14230-4, ISO 9141-2   2002 ISO 14230-4, ISO 9141-2 2.0 TDi, Diesel (185HP) 2006 KWP SLOW 1.9 TDI, Diesel (105HP) 2007 KWP SLOW Bensin (148 HK) 2005   Volkswagen Jetta Wagon   2003 ISO 14230-4, ISO 9141-2 Volkswagen Kafer 1600i, Bensin (46 HK) 1997 ISO 9141-2 Volkswagen Lupo (1,0l ANV) Bensin (50 HK) 1999 KW 1281 (1,0l ANV) Bensin (50 HK) 1999 ISO 9141-2 1.0L, Bensin (50 HK) 1999   (1,0l AUC), bensin (53 hk) 2000 KW 1281 1.4L, Diesel (75hp) 2000 ISO 9141 Diesel (60 HK) 2001 KW 1281 1,2 TDI 3L AYZ, Diesel (61 HK) 2001 ISO 9141-2 Bensin (74 hk) 2003 ISO 9141-2 Bensin (74 hk) 2003 ISO 9141-2 Bensin (74 hk) 2003 ISO 9141-2 1.4, Bensin (58 HK) 2004 KW 1281 1,0l ANV) Bensin (50 HK) 1999 ISO 14230-4, ISO 9141-2 Bensin (60 hk) 2004 KW 1281 Volkswagen Lupo 3L 1,2TDI, Diesel (61 HK) 1999 KW 1281 Diesel (61 HK) 2000 KW 1281 Diesel (61 HK) 2000 KW 1281 Diesel (61 HK) 2000 KW 1281 1.2 TDI, Diesel (61 HK) 2000 KW 1281 Diesel (61 HK) 2003 ISO 14230-4, ISO 9141-2 Volkswagen Lupo FSI (ARR) Bensin (104 HK) 2001 ISO 9141-2 Volkswagen Multivan Bensin (202 HK) 2001   Diesel (129 HK) 2006 KW 1281 Volkswagen New Beetle 1.8 Turbo, Bensin (150HK) 2000 ISO 9141 Bensin (114 HK) 2001   1.6 SR, Bensin (105HP) 2001 ISO 9141 Bensin (97 hk) 2002 KW 1281 1.9 TDi, Diesel (90 hk) 2002 ISO 9141 Diesel (100 HK) 2006 ISO 9141-2 1.6, Bensin (102HP) 2010 ISO 9141 Volkswagen New Beetle Cabriolet 1,6l, Bensin (101 HK) 2003 ISO 9141-2 Volkswagen Passat Bensin (89 hk) 1990   Bensin (89 hk) 1994 KW 1281 TDI, Diesel (135 HK) 1994   Bensin (100 HK) 1995   Diesel (109 HK) 1995 KW 1281   1996 ISO 14230-4, ISO 9141-2   1997 ISO 14230-4, ISO 9141-2 Diesel (89 HK) 1998 KW 1281 Bensin (148 HK) 1998   Bensin (191 HK) 1998   1.9 TDi, Diesel (110HP) 1998 ISO 9141   1999 ISO 14230-4, ISO 9141-2 V6 TDI, Diesel (148 HK) 1999 KW 1281 1.8 20v, Bensin (95HP) 1999 ISO 9141 2.5 TDi, Diesel (150HK) 1999 ISO 9141 Diesel (109 HK) 2000   Bensin (124 HK) 2000 KW 2000 VAG 1.9 TDi, Diesel (115HP) 2000 ISO 9141 Bensin (191 HK) 2001   1.9 TDI Variant (3BG), Diesel (100 HK) 2001 KW 1281 2.0, Bensin (168 HK) 2001   1.9 TDi, Diesel (105HP) 2001 ISO 9141 1.9 tdi, Diesel (130 hk) 2001 ISO 9141 2.5l v6, Diesel (150HK) 2001 ISO 9141 1.8 Turbo, Bensin (170HP) 2001 ISO 9141 Diesel (100 HK) 2002   Bensin (148 HK) 2002   1.9 TDI PD, Diesel (100 HK) 2002 KW 1281 1.9 TDI PD Kombi, Diesel (100 HK) 2002 KW 1281   2003 ISO 14230-4, ISO 9141-2 Bensin (129 HK) 2003   1.9 TDi, Diesel (90 hk) 2003 ISO 9141 1.9TDI Kombi (3BG), Diesel (100 HK) 2004 KW 1281 1.9 tdi, Diesel (105HP) 2005 KAN 11bit (500 kbps) 1.9 TDi, Diesel (130 hk) 2005 ISO 9141 2.0 tdi, Diesel (140hp) 2005 KAN 11bit (500 kbps) 1.9 tdi, Diesel (90 hk) 2006 KAN 11bit (500 kbps) Diesel (129 HK) 2003 KW 1281 Diesel (161 HK) 2005   Diesel (129 HK) 2002 KW 1281 Diesel (129 HK) 2004 KW 1281 Bensin (114 HK) 1994   Motor: 2E, Bensin (114 HK) 1994 KW 1281 Diesel (89 HK) 1995   Bensin (89 hk) 1995   Bensin (89 hk) 1995   Volkswagen Passat 35i - Variant Bensin (114 HK) 1994 KW 1281 Volkswagen Passat 35i ADZ, Modelljahr 96, Automatik, Bensin (89 HK) 1995 KW 1281 Volkswagen Passat 35i Facelift / 3A5 Bensin (89 hk) 1994   Volkswagen Passat 35I MKB ABF Bensin (148 HK) 1994 KW 1281 Volkswagen Passat 3A (MKB: AFN) Diesel (109 HK) 1995 ISO 9141-2 Volkswagen Passat 3b (AEB motor), Bensin (148 HK) 1995 KW 1281 Diesel (109 HK) 1997 KW 1281 Diesel (109 HK) 1998 KW 1281 Diesel (109 HK) 1998   Bensin (148 HK) 1998   Diesel (109 HK) 1998 KW 1281 Diesel (114 HK) 1999 KW 1281 Diesel (89 HK) 2000 KW 1281 Diesel (116 HK) 2000 KW 1281 1,8l 20V, Bensin (168 HK) 1997 KW 1281 2.3 10V VR5, Bensin (148 HK) 1998 KW 1281 Diesel (109 HK) 1998 KW 1281 Volkswagen Passat 3B Limousine Bensin (124 HK) 1997 KW 1281 Volkswagen Passat 3B5 Bensin (124 HK) 1997   Bensin (148 HK) 2000 CAN Diesel (148 HK) 2000 KW 1281 Diesel (109 HK) 1997 KW 1281 Bensin (124 HK) 1999 KW 1281 Diesel (114 HK) 2000 KW 1281 Volkswagen Passat 3B6 Diesel (129 HK) 2002   Volkswagen Passat 3BG Diesel (129 HK) 2001   Diesel (129 HK) 2001 KW 1281 Bensin (148 HK) 2001 KW 1281 Diesel (129 HK) 2002 ISO 9141-2 Bensin (161 HK) 2002   Diesel (129 HK) 2002 KW 1281 Bensin (148 HK) 2002 KW 1281 Diesel (129 HK) 2002 KW 1281 Diesel (100 HK) 2003 KW 1281 Diesel (129 HK) 2003 KW 1281 Diesel (129 HK) 2003 ISO 9141-2 Bensin (191 HK) 2003   Diesel (129 HK) 2004 KW 1281 1.9 TDI Variant, Diesel (129 HK) 2004 KW 1281 Volkswagen Passat 3BG Variant 1.9 PD, TT5, Diesel (129 HK) 2003 KW 1281 Volkswagen Passat 3C Diesel (139 HK) 2006 CAN Diesel (139 HK) 2007 CAN Diesel (102 HK) 2005   Diesel (102 HK) 2005   Volkswagen Passat AVB 3B6 Diesel (100 HK) 2001 KW 1281
VAG fra ca 1994 til ca 2004 har ODB2 med 16-pins kontakt, og elektrisk K-line (uten CAN-bus).
Eldre modeller har ikke 16-pins kontakten men 2x2 pins kontakt.
Nyere VAG har bare CAN-bus, men samme 16-pins kontakten.
På din bil kan du bruke en VAG-COM kabel til en 100-lapp koblet til en PC.
