Feilkoder for avgass og ESP
AutoSnuskus
Hey :)
Fått ett par feillamper i dash. Hatt diagnose på dette i dag uten å bli no klokere. Så jeg tenkte prøve her før det blir mer verksted.
Avgass:
P0113 Inntakslufttemperaturkrets: mating høy ( pemanent )
P0238 Ladetrykkføler, for høyt signal ( permananent )
P0238 Høy krets turboladerens/kompressorens føler "A"
P0113 Inntak lufttemperatur sensor 1 krets høy ( bank 1 )
ESP:
01435 Bremetrykksensor 1 ( feil i krets, permanent )
Er det no håp for noe selvfiks?
Caddy 2007 1.9TDI
VW CADDY 1.9 TDI 2007
  • 2 months later...
01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Basic Setting not performed
Possible Solutions
Perform Basic Setting
01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Possible Causes
Brake Pedal Switch (F) faulty/jammed
Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
Check/Replace Brake Pedal Switch (F)
See Measuring Blocks
Check/Replace Brake Pressure Sensor 1 (G201)
ABS Hydraulic Unit (N55) may need to replaced
Perform Brake Pump Bleeding
Perform Brake Pressure Sensor 1 (G201) Basic Setting
Replace Brake Electronics Control Module (J104)
Administrator
