No instrument lights / Starting problem - GOLF 1.9 TDI 2005
VWGOLF4-MOTION
Hello.
And first, thanks to those of you who can help me with this. Have tried searching the forum for clues, but now I need some more specific help.
The car will start and run for 1-2 seconds without problems before dying. But there is no instrument/warning lights in the instrument before or after it starts, only the milage and outside temperature showing in the display. Electrical windows, radio, locking system and such are working as normal. It's a 2005 VW Golf 1.9 TDI 4-Motion, engine; BKC/BKE
Things I tried:
1. New and fully charged battery
2. Spare keys and also a new key with new immobilizer programmed
3. Checked all the fuses and relays next to the battery and under the dashboard, even tried to change some of the relays.
4. ''Vag-com readout gives limited information as it can't fully connect with the ECU'' -what I were told by the workshop
Things I still have to try or hopefully first exclude with your help:
1. Diesel pump. It seems to work, and the one under the back seat deliver diesel to the pump. And if there were a problem with the pump, would the car start every time just fine, but cut out after 1-2 secounds? Also it does not explain the missing lights in the insturment panel, or would those be missing if there were a problem with the pump?
2. Ignition switch? I read in the forums this were mostly a problem on the older generations? Also this were a sudden problem accuring, with no warning or other faults. Also I tried to turn over the key very slowly, ''wiggle'' it, etc, no difference. Also it seems like most people having a problem with it don't get the car to start at all?
Snakker/skriver norsk også smile.gif
Hei.
Takk for svaret. Det var mye korrosjon/irring rundt ledningene/sikringene på front siden av sikring/rele panelet ved batteriet. Men har pusset bort dette og målt/sjekket alle ledninger/sikringer, ingen forskjell.
Jeg kan ikke så mye om biler. Men kan du forklare litt rundt hvordan comfort modulen kan gjøre at bilen ikke går mer enn 1-2 sekunder og det er ingen instrumenter? All elektronikk jeg forbinder med med comfort modulen virker som det skal?
Takk igjen:)
Comfort er den som styrer all elektronikken som er inni bilen.
Både til tening og alt du har i displayet på bilen.
Også om ecu har blitt utsatt for noe så kan den også gi feilmelding.
Nå har jeg litt mistanke på at du har kanskje at  problemet ditt er.  Immobilizer control module j362 som igjen gjær så at motoren blir stengt/slått av.
Regner med at det er denne du må se nærmere på..?
Enten ingen kontakt strømbrudd feil/defekt må byttes..
Det er typisk startsperre ja. Derfor jeg kjøpte ny nøkkel og fikk denne programert med startsperren, men var ingen forskjell. Men problemet er også at det ikke kommer opp noe annet i instrumentpanelet enn km-standen. Ville ikke alle lys kommet og gjerne en egen varsellampe for startsperren om det var kun den som var problemet? Virker som det er noe som hindrer tenningen å kommunisere med ECU som igjen trigger startsperren, som også kutter instrumentene?
Nå er det Comfort modul som styre alle varsellampene.
Så dette henger nok sammen, og da får heller ikke bilen kommunisert med ecu.
Og om det er feil på Immobilizer control module så vil heller ikke bilen starte, så har du feilen som Jesper sa.
Dette kan du ha fått problemer med etter du fikk programmert nøkkelen.
Kan også  plutselig oppstå om det er noe strøm feil på bilen.
Det kan hende du trenger å få dette opprogramert .
Om du har vag com eller kjenner noen som har, så ville jeg prøvd å ta en test med den.
Eller se om noen her kan ta en diagnose i nærheten av der du bor.
http://www.bilforumet.no/topic/291109-problemer-med-bilen-trenger-du-diagnose/
Okei, takk. Skal prøve på det i morgen. Bilen står på et verksted som har vag com, men har overatt feilsøkingen selv da jeg fant ut dette ville bli uendelig dyrt å betale en mekaniker til å gå over alle mulige feilkilder.
Men, et spørsmål. Trodde instrumentpanelet/varsellampene var en del av ECU/koblet direkte til ECU?
Skal også gå over jordingspunktene, spesielt til ECU. Har søkt etter en liste med jordingspunktene, men har ikke funnet dette enda. Vet du hvor jeg kan finne en slik liste?
Tekte du på kablene ut fra ECU..?
    wiring set for engine   diesel eng.:
AXR,ATD,ASZ   (1)
                                 wiring set for engine       (1)
                                 wiring set for engine   automatic       wiring set for engine
F >> 1J-3-900 000   diesel eng.:
ARL   (1)
                                 wiring set for engine           wiring set for engine
F 1J-4-000 001>>   diesel eng.:
ARL   (1)
                                 wiring set for engine           individual parts
* corrug. tubes, t-pieces,
* clips, holders, grommets,
* cable ties, insulating
* hose, wiring,
* single wires and seals
* see special catalogue:
* electrical
* connecting elements       2
                                 flat contact housing with cap
control unit 40 pin     (3)
                                 flat contact housing with contact locking mechanism
temperature sensor
for coolant temperature gauge 4 pin     4
                                 contact bridge with loom       (4)
connecting part
glow plug
ARL   5
                                 sealing tape 220X60X4     (6)
                                 cable holder
hole/sheet metal thickness: 6,5 / 0,8-1,5     (7)
                                 bracket protective cover
connecting part
flat contact housing 1J0 973 702     (7)
                                 protective cap
connecting part
flat contact housing 14 pin
1J0 973 837     7A
                                 heat deflector hose
connecting part
distance sensor       (7A)
                                 heat deflector hose
connecting part
oil level sensor 260MM     8
                                 flat contact housing with gasket
connecting part
impulse sender 3 pin
black     9
injection nozzle 8 pin     (10)
oil pressure switch 1 pin     11
temperature sensor
fuel line 2 pin
black     12
distance sensor
oil level sensor 3 pin     12        flat contact housing with contact locking mechanism
distance sensor
oil level sensor 3 pin     13
speed sender 3 pin
grey     14
coupling element
central wiring set 2 pin     (15)
coupling element
central wiring set 14 pin     16
                                 cable ties 3,6X246     17
connecting part
flat contact housing 2 pin     18        cable ties
hole/sheet metal thickness: 4,5X200
6,5 / 0,3-3     18        cable ties
6,5 / 0,3-3     20
                                 bracket for corrugated pipe 17     21
                                 bracket
connecting part
oil filter bracket
line
for alternator       (21)
                                 bracket
connecting part
starter       21A
                                 guide piece
connecting part
oil filter bracket
line
for alternator       22
                                 bracket
connecting part
oil filter bracket
line
for alternator   5-speed automatic   23
                                 cable guide   5-speed automatic   (23)
                                 cable guide
connecting part
battery mounting   5-speed automatic   24
                                 cable guide - upper part   5-speed automatic   25
                                 bracket
connecting part
for 5-speed automatic gearbox       26
                                 bracket
connecting part
for 5-speed automatic gearbox       27
                                 bracket
connecting part
wiring
oil level sensor       28
                                 retaining clip
wiring
oil level sensor           adapter cable loom
injection nozzle       30
                                 adapter cable loom
injection nozzle           individual parts       31
injection nozzle 2 pin     32
                                 cable guide       33        double stud with hexagon drive
connecting part
adapter cable loom
injection nozzle M6X16
Update about the ignition switch(2); There is no power coming from the ECU/engine bay to the ignition, still it starts for 2 seconds. Vag COM also had connection with the ignition or cluster? (repgrommed the new key with immobilizer). Wag COM seems to have no connection with ECU as it seems like the ignition is turned off since no power reaches the ignition?
