upgrading braking system for touran 2012
Ian
  • 4 weeks later...
Hi, still looking for Big Brake Kit.?
Take a look here --> http://bit.ly/2gEMlgi (shorten link for easy use)
Are You looking for only BBK for the front, ore Front & Rear.?
Some importan info, most People don't scroll Down so far that they see this info, and REMEMBER..!  ASK for TEMPLATES before You make any order.
ROTOR SIZE vs WHEEL SIZE:
We advise the following guideline for fitment. These guidelines will work for most wheels as the outer diameter of the BBK will fit in the inner barrel. In some cases due to the design of the wheel spoke, you will need spacers to clear the spoke depending on the size of BBK kit chosen, and the wheel design. If you want to know if you will need spacers or not before purchasing, you can email us at contact-us@ceikaperformance.com with your car model, year, and wheel size, and we will email you the templates to print and check precisely.
Maximum rotor diameter/kit size per wheel diameter:
15" wheel: 286mm/304mm
16" wheel: 304mm
17" wheel: 330mm
18" wheel: 356mm
19" wheel: 380mm
20" wheel: 405mm
I took a look here --> http://www.brembo.com/en/Varie/BremboGTR_ApplicationList.pdf
to see if Your car was listed, it was not.!
