Feilkode P0010
Jokva
P000A/000010 - Camshaft A (Bank 1 Intake): Positioner Slow Response
Possible Causes
  • Camshaft Adjustment Valve 1 (N205) faulty
  • Wiring/Connectors from/to Camshaft Adjustment Valve 1 (N205) faulty
  • Intake Camshaft Adjustment (Bank 1) faulty
Possible Solutions
  • Check Camshaft Adjustment Valve 1 (N205)
    • Perform Output Test
  • Check Wiring/Connectors from/to Camshaft Adjustment Valve 1 (N205)
  • Check Intake Camshaft Adjustment (Bank 1)
    • Perform Basic Setting
    • Check for Tightness of the Adjustment Mechanism
    • Check Engine Oil Pressure
Special Notes
  • When found in 2008 and newer VW 2.0T engine with a timing chain (example; CCTA and CBFA), please see:
    • TT 01-15-08 for information about the intake camshaft, adjuster bridge and spool valve.
Kan noen ganger ses i sammenheng med 17939;
17939/P1531/005425 - Camshaft Timing Adjustment: Open Circuit
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205) faulty
  • Camshaft Adjustment Valve (N205) faulty
Possible Solutions
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205)
  • Check/Replace Camshaft Adjustment Valve (N205)
http://wiki.ross-tech.com/wiki/index.php/P000A/000010
Administrator
