bvorland Skrevet Juli 3, 2020 Rapporter Share Skrevet Juli 3, 2020 Hi Forum,This is my first post so feel free to move it to the correct thread.So the issue at hand is that the AC clutch will not engage, all the fans a blowing when running the test on the Auto HVAC moduleI have changed the solenoid valve on the compressor, and filled with coolant and leak stop. On the first run of VCDS there are some Intermittent error codes.-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 1K0-907-044.lblPart No SW: 1K0 907 044 DA HW: 1K0 907 044 DAComponent: ClimatronicPQ35 133 1213Revision: 00133026 Serial number: 00000000000000Shop #: WSC 00000 000 00000VCID: 698FBB69357217C3E45-803C3 Faults Found:01809 - Actuating Motor for Temperature Flap; Left (V158)000 - - - Intermittent00898 - Control Circuit A/C compressor010 - Open or Short to Plus - Intermittent01314 - Engine Control Module004 - No Signal/Communication - Intermittent-------------------------------------------------------------------------------I have cleared the codes, and when I run the car and turn on the AC and at the same time check the values on the pressure, fan speed and it all looks good except for "Fresh Air Intake Temperature" there are no reading on that value, so could this be my issue?I have read somewhere that all this sensor are in serial, so they all need to deliver value within scope or the AC will not start.. Ref:Address 08: Auto HVAC (1K0 907 044 DA)20:58:25 Group 001: General0.0 Compressor Shut-Off Code1500 /min Engine Speed48.0 km/h Vehicle Speed00:02 Standing Time20:58:25 Group 002: Compressor0.820 A Compressor Current (actual)0.820 A Compressor Current (specified)1900 /min Compressor Rotations1.3 Nm Compressor Load20:58:25 Group 004: Temperatures16.5°C Outside Temp. Unfiltered17.0°C Outside Temp. Regulation- Fresh Air Intake Temperature85.0°C Coolant Temperature Hope you have some insight into this, my local car dealer has given up on the case, and with a 4-6 weeks waiting line on VW dealer I would like to resolve this before the summer set in. brBjørn Atle Siter Lenke til kommentar Del på andre sider More sharing options...
