Change oil og olje lampe lyser rødt
Kris80
  • Turn the ignition to position On without starting the engine.
  • Press the DIC MENU button on the turn signal lever
  • Scroll up and select "REMAINING OIL LIFE" by use the thumbwheel
  • Press the SET/CLR button
  • Turn the ignition off and start the engine to verify the indicator has been reset.
Prøv dette.
Administrator
