a007apl Skrevet Mars 25, 2002 Rapporter Share Skrevet Mars 25, 2002 2WD & VT _____________ Engine Engine Layout = Mid engine (86.32 hp/L) Engine Type = 48-valve DOHC V-12 Displacement = 5707 cc - 5.7L, 348.26 cu in Horsepower = 492 (529) Bhp @ 7100 Rpm Torque = 443 lb-ft @ 5500 Rpm Max engine speed or Redline = 7300 Rpm Fuel EPA City/Highway = 10/14 mpg _______________________________ Dimensions Wheelbase = 104.3 in Height = 44.2 in Width = 81.6 in Length = 178.8 in Weight = 3575 (3570) lbs Weight Distribution f/r = 40 %/60 % _______________________________ Performance 0-60 mph (Acceleration) = 4.0(4-4.2) sec 0-100 mph = 10.3(10.5) sec 0-150 mph = n/a 1/4 mile = 12.5(12.6) sec @ 115 mph 1 km = 20.7 sec Top speed = 202.1 mph (205-208), (325.97 km/h) _______________________________ Brakes & Tires Tires f/r = 235/40ZR-17f,335/35ZR-18r Brakes (Brembo) = Vented cross drilled discs Braking distance from 70-0 mph = 164 ft(126 ft from 60) _______________________________ Drivetrain & Gears Transmission = 5-speed Manual 1st Gear = 2.31:1 2nd = 1.52:1 3rd = 1.12:1 4th = 0.88:1 5th = 0.68:1 6th = none Reverse = n/a Final Drive ratio = 2.49:1 _______________________________ Other Lateral Acceleration in G force = 0.93g (0.94g+) Drag ratio ( Cd ) = 0.31 Down force ( Cz ) = n/a Siter ...From Brazil to F1 History... Lenke til kommentar Del på andre sider More sharing options...
psychoExtreme Skrevet Oktober 17, 2003 Rapporter Share Skrevet Oktober 17, 2003 syntes det var latterlig lite lateral G!!! må da være feil,en mr2 ha jo bedre enn det her.. Siter Eg blir i godt humør av øl! Visste du at... -Menn bommer ikkje på doskåla fordi dei slurver, men for å markere sitt revir! Lenke til kommentar Del på andre sider More sharing options...
