Bleeding clutch, leakage
skåda
Hello. Does not get a tight connection on the input clutch pipe to the slave cylinder. Have changed to a new slave and a new O-ring. Hears Click from the locking spring when I push the tube in. Don't understand why the connection doesn't close. Has anyone else suffered from this?  UPDATE: There was a bigger second seal stuck in the bottom. Now everything is fine
  • skåda changed the title to Bleeding clutch, leakage
