Street legal redline
Kjøp en Duhen, helst 2.0 hvis du finner. Kjøp komplett GT2 running gear untatt fjærene. Kjøp 6.5" GT3-fjærer. Så kjøper du 295/20 R19 dekk og 13x19 ET+0 felger. Kjøp en fakten group 6 girkasse med RWD extension. Da har du 4WD;). I tillegg kan du fikse på gear-ration. Så bygger du følgende motor:
-Duhen D22V Block.
-Duhen D22V crankshaft.
-Duhen Crankshaft Bearing Bridge.
-Duhen Oil Pan.
-Duhen D15V/18V/20CV Connecting Rods.
-Duhen SunStrip 1.5 DVC Pistons.
-Duhen Alternator.
-Baiern Devils 65Fi 3.6 Flywheel.
-Baiern Kraftwerk 2.5 Clutch.
-Faktun Group Tran6 6 Speed Sport Transmission.
-Faktun Group Tran6 Center Differential.
-Ishima WR Cylinder Head.
-Duhen DVC Intake / Exhaust Camshafts.
-Ishima Camshaft Bearing Bridge.
-Ishima WR Superturizmo Cylinder Head Cover.
-Duhen Camshaft Drive Belt.
-Duhen Solar Wind Exhaust Header.
-Shimutshibu RC MWFCR22W12 Turbocharger.
-Shimutshibu RC HIB535T4 Intake Manifold.
-SL Tuners 4 Channel Methanol Injection Fuel Rail.
-SL Tuners 4 Channel Ported N20 System.
Så tuner du den slik:
-Duhen DVC Exhaust Camshaft -14.
-Duhen DVC Intake Camshaft: -13.
-SL Tuners 4 Channel Ported N20 System: 359.0
-SL Tuners 4 Channel Methanol Injection Fuel Rail: 16.00
-Duhen D22V Block: Idle 650rpm, Redline 7000rpm.
Jeremy Clarkson on Norway:
"Enviromentalists say that when the golf stream stops, Britain will look like this. Bring it on!"
