ma audio
Odd Arve
Er det noen som har erfaringer med en ma-audio monoblokk som heter hk 1997 1X1200WRMS 2Ohm. Thermal, Short & Overload Protection Circuitry Platinum Plated Screw Type RCA Jacks Double Sided Black Epoxy PCB Board Variable High Pass & Low Pass Filters Platinum Plated Block Terminals Fully Regulated Power Supply Stainless Steel Finish Heat sink 0-18dB Variable Bass Boost Quiet Fan Cooling System Full Mosfet Circuitry 2 Ohm Stereo Stable THD: <0.05% Signal to Noise: >90dB
Er denne noe å satse på får kanskje tak i en brut slik for 1600.
