Nullstille service indikator
ArraKiss
Prøv dette:
Service Reminder Indicator (SRI), resetting after service (without VAG1551/1552)
After performing service, the respective Service Reminder Indicator (SRI) must be reset.
The Service Reminder Indicator (SRI) can be reset using the "Adaptation" function of the VAG1551 scan tool
Additionally, the SRI can be reset using the following method:
Switch ignition off.
Press odometer and instrument cluster reset buttons while switching ignition on.
The following will appear on the odometer display: "OIL" (m.y. 1997) or "service OIL" (m.y. 1998 )
The following will appear on the odometer display: "- - -" (m.y. 1997) or "service - - -" (m.y. 1998 ).
Pull clock button until "OIL" or "service OIL" are reset.
Press odometer reset button again advance to next service event.
The following will appear on the odometer display: "INSP" (m.y. 1997) or "service INSP" (m.y. 1998 ).
Pull clock button until "INSP" or "service INSP" are reset.
The following will appear on the odometer display: "- - -" or "service - - -".
Passat 1.8T variant
Bilen min
Hadde min 97 mod A4 inne på NAF test for noen mnd tilbake. Skulle da nullstille min service indikator, noe de ikke fikk gjort pga feil på maskinen som skulle nullstille indikatoren. Lurer på om man er nødt til å kople en maskin til for nullstille...
- 98 Audi A6 1,9 Tdi
x97 Audi A4 1,8 20V (solgt)
x87 Mercedes 190E 2,3 (solgt)
x87 Mercedes 190E 2,0 (solgt)
x81 Ford Escort 1,3 (taket)
