Syk forsterker
Veryfied
Selger min 3 måneder gammle MA audio HC 4002 forsterker.
Dette er et digert beist som er sikra til 160 amp på utsiden (4 X 40) og skal klare 2 X 2000 w RMS i 1 ohm..1 X 4000 W RMS i 0.5 Ohm
Monsteret er hele 70 CM lang og veier 8,5 Kg..Stappet med godsaker!:)
Ny kostet denne 7000, jeg fikk den for 5000, og selger den videre for 3500 til førstemann som slenger penga på boret.
Selger også en MDS kasse med 2 X 12"..1600w max, 800 w RMS.
Spiller veldig bra..Kassa selges for 2000.
Send en mail til Buck@halden.net eller ring på 97724818 om noen er intressert.
Mvh,
Kjetil Eng
Her kommer litt mer fakta:
FEATURES
MA Audio is a manufacturer known for supplying high performance car electronics and audio from amplifiers to subwoofers to video. As they continue into the millennium, their intention is to provide you with absolutely the best car audio and video products and technology available today.
See you in the Winner’s Circle!!!
HC Series features:
High Current,Non-Regulated Power Supply
Double Sided PCB
Cooling Fan (Thermal Regulated)
24dB Active Slope Crossover
18db Variable Frequency Bass Boost
Variable Phase Shift(180 degrees)
VU Meters
Line Out
Protection Sattus Indicator
Specifications:
Bass Frequency Range: 45Hz to 90Hz
Bass Boost: 0 - 18db
Frequency Response: +- 1dB from 10Hz to 40KHz
Signal to Noise Ratio: > 100dB
Input Sensitivity: 100mV to 7V
Channel sepatation(AT IW): > 60dB
Damping Fator(ATIW / 50Hz): >240
Typical Current Draw At IDLE: 1.4Amps
Stereo Power
Into 4 Ohms @ 13.8V DC : 2 x 400W
Into 2 Ohms @ 13.8V DC : 2 x 700W
Into 1 Ohms @ 13.8V DC : 2 x 1200W
Into 0.5 Ohms @ 13.8V DC : 2 x 2000W
Mono Power:
Bridged Into 1 Ohms @ 13.8V DC : 1 x 4000W
Recommended Fuse Size:
HC4002: 40A x 4
Dimensions:
2.3" x 10.8" x 26.4" (H x W x L)
Som blir : 5.8 Cm X 27,4 Cm X 70 cm
