Diverse bilstereo utstyr
sfh
RESTLAGER PÅ DIVERSE UTSTSYR:
VEIL UT-PRIS PER STYKK/PAR/SETT/METER :
CALIBER:
10STK : 25.5 PT - 25MM2 RINGSPADE M/5MM HULL, GULL,_= 8,-=50%
2PAR : 602 CL - RCA-PLUGG, GULL, SORT/RØD-MERKET,_= 30,-=50%
2STK : 150 WF - 150A WAFER/ANL SIKRING, SVART/GULL,_= 20,-=50%
2STK : 569 FH - 10~25MM2 SIKRINGHOLDER, INLINE, STANDARD, GULL,_= 30,-=50%
6STK : 153 CL - YLEDD RCA, MØRKBLÅ, DUAL-SHIELDED,_= 15,-=50%
3.4M : 25 CN - 25MM2 STRØMKABEL, SVART,_= 30,-=50%
2STK : 70 CF - DEMPEMATTE TIL BASSREFLEKS KASSE, KVIT, 70X200CM,_= 70,-=50%
2STK : 60 BL - 60CM BLÅ, NEONLYS-STRIPE, FLEKSIBEL"TRÅD" SOM LYSER,_= 140,-50%
2STK : 60 RD - 60CM RØD, NEONLYS-STRIPE, FLEKSIBEL"TRÅD" SOM LYSER,_= 140,-50%
1STK : 100 RD - 1M RØD, NEONLYS-STRIPE, FLEKSIBEL"TRÅD" SOM LYSER,_= 165,-=50%
1STK : 100 BL - 1M BLÅ, NEONLYS-STRIPE, FLEKSIBEL"TRÅD" SOM LYSER,_= 165,-=50%
2STK : 40 BL - 40CM, NEON, BLACKLIGHT ,SIGARETT-PLUGG,_= 210,-=50%
4STK : 100 PO - 10CM Ø,50CM LENGDE, BASSREFLEKS RØR,U/FLENSER,_= 45,-=50%
BASIC:
5M : 10MM2 STRØMKABEL, RØD,_= 50,-=FOR 5Msolgt
1M : 10MM2 STRØMKABEL, SVART,_= 15,-solgt
2,1M : RCA/SKJØTE KABEL, BLÅ, DUAL SHIELDED,(RESTKAPP AV 5M-KABEL),_= 30,-
17M : 2X4MM2 HØYTT.KABEL, PÅ RULL, TRANS, STANDARD,_= 12,-=50%
AUDIOBAHN:
8STK : 80A AGU-SIKRING/GLASS, M/LYSDIODE, (LYSER NÅR BRENT)_= 15,-=50%
MDS: (beregnet %)
1STK : AUDIOPHILE 12", 400W,4OHM,100-OZ,ALU-MEMBRAN, REFLEKS ANB, %OFF_= 1495,- =1000,-solgt
denne sub spiller ganske fint og med bra trøkk i en 50L bassrefleks.
2STK : FANATIC REF.8", 200W,4OHM,40-OZ,REFLEKS ANB, ELLER MIDBASS,%OFF_= 799,- = 500,-
desse ble kun prøvd som midbasser sammen med 2-veis komposett å det funka veldi bra. de gir oki lyd som sub også (desse er ikke brukt som sub)
1STK : DEMPEMATTE, 70X90CM, LYSBLÅ, TIL REFLEKS-KASSE INNVENDIG,_= 40,- 50% solgt
SFH: (beregnet %)
15PAR : KABELSKO, SMAL/FLAT/HUNN, 4MM2 KABEL, GULL,SORT/RØD_= 2,- = 50,-=for alt
11PAR : KABELSKO, BRED/FLAT/HUNN, 4MM2 KABEL, GULL,SORT/RØD_= 2,- = 40,-=for alt
10PAR : KABELSKO, SMAL/FLAT/HUNN, 2MM2 KABEL, GULL,SORT/RØD_= 2,- = 40,-=for alt
12PAR : KABELSKO, BRED/FLAT/HUNN, 2MM2 KABEL, GULL,SORT/RØD_= 2,- = 40,-=for alt
7stk : RØDE, KABELSKO, SMAL/FLAT/HUNN, 4MM2 KABEL, GULL,_= 2,- = 10,-=for alt
7stk : SVART, KABELSKO, BRED/FLAT/HUNN, 4MM2 KABEL, GULL,_= 2,- = 10,-=for alt
12stk : RØDE, KABELSKO, SMAL/FLAT/HUNN, 2MM2 KABEL, GULL,_= 2,- = 15,-=for alt
7stk : SVART, KABELSKO, BRED/FLAT/HUNN, 2MM2 KABEL, GULL,_= 2,- = 10,-=for alt
1stk : AEROPORT, 6", 2PORTER, 2RØR PÅ 23CM OG 30CM, SVART, UBRUKT_= 459,- = 200,-=for alt
**EDIT: har satt opp priser med 50% off, skal/må vekk..**
**Alt er nytt fra forhandler, er det brukt/prøvd er det også opplyst**
Har også kickpaneler til E30, i glassfiber og beregnet for 6.5"bass med vinkel for oki/bedre/løftet lydbilde..
de er fortsatt et rå-bygge og trenger litt puss, sparkel og finish..lakk eller vinyl/teppe funker bra.
noe interrisant..?
mvh, :D
1986 bmw 318i
1987 Ford Escort xr3i
ja egentlig, har noen grønne neonlys, men har rød bil så egentlig skulle jeg ha rødt neon. Men testa det, og det passet faktisk fint med grønt neon, men det kan ha litt med at jeg ikke har kjæsj rød bil, men burgunder rød.
Hvor mye koster det for neonrør hos deg da ? (røde)
2002 Audi A6 TQ
1887 VW Polo
utenom de røde/blå NeonWires du ser på bildet (ved siden av Y-ledda) så kan jeg vel skaffe hva som helst ;)
kommer litt an på hvor mye lys du vil ha ut av de.. de neonstripene er smarte til å snurre rundt en kromma magnet feks..eller legger rundt/på noe man vil markere er der..feks i rillene på en forsterker har blitt gjort..
ellers har man vel de store vanlige røra på 20cm og 40cm,
og noen tynne 4mm rør kalt neon-stick..: koster veil.250,- for 30cm. neon stick leveres bare å blå, grønn og blacklight..
pers syns jeg blå eller grønne neon passer best til rød bil..
syns rød bil og rød neon blir for mye rødt :D
men kommer også an på hvordan du bygger det i bagasjen og hvor lysa passer som best..må jo plasseres så du ser bare lyset,ikke røra...
ellers fungerer neon bare i mørket uansett ;) hadde nå vært best med farga halogen-pærer spør du meg..hehe..
mvh, :D
1986 bmw 318i
