Kjøpt meg "ny" bil! noen spørsmål!
MeSs
Traversen er OK!
500kr -og da sandblåser og zink-behandler jeg den.
(bare å lakere i valgfri farge)
Men jeg ville satt i nye foringer
(dumt å montere noe som er brukt, selv om de er OK).
Jeg kan sette i nye for 1500kr ink. foringer!
Har også noen bra, men brukte bremseskiver m/klosser, som bare har gått noen tusen! (hvis du er blakk)
250,- foran 150,- bak
Trenger fortsatt å vite farge på seter!
Ring med eventuelt på 4826 9484
Morpheus....HansK
Han sier fortsatt det er denne motoren :rolleyes: :
Alpina B6 -
"After BMW fitted six cylinder engines Alpina was soon to follow. But not the new 2.3 litre engine of the 323i stood model for the first six cylinder Alpina E21, but the 2.8 litre engine of the 528i. It fitted only just, the battery was placed in the boot, also to distribute weight better.
The modifications to the engine included modified combustion chambers, a higher compression ratio, the Solex Pierburg Zenith DL fuel injection unit, different camshaft and a revolutionary rotor-less digital electronic Hartig ignition unit. In 1981 the 2.8 litre unit was upgraded with the Bosch L-Jetronic fuel injection and power rose from 200 to 218 BHP."
Engine
B6 2.8 (9/81-1/83)
Type:
inline watercooled 6
Engine code
M30 B28
Bore x Stroke mm
86 x 80
Displacement cc
2788
Valve Operation
SOHC
Camshaft (degrees)
280
Valves / cyl
2
Compression Ratio
9.6 : 1
Injection / Carburetor:
Bosch L-Jetronic
Max Torque
265Nm @ 4500
BHP (DIN)
218 @ 6000
Noen kjennetegn???
MeSs
98' E36 Stasjonsvogn. x - 2006 VW Golf GT TSI 170HK, x- 03 E46 320i Sport
x- Toyota Hiace trekkbil, x- 91 200SX S13 Driftbil.
x - NA 1994 Mazda Miata 1.8
x - Mange BMW E28.
