Hvad siger i?
ziegler
Jeg har langt om længe fundet frem til dette nedenstående set, hvad siger i til det, har i andre ideer?
2*
KICKER S12L7
aluminum deposit cone
non-resonant aluminum basket
Santoprene rubber surround
dual 4-ohm voice coils for wiring flexibility
frequency response 20-100 Hz
power range 75-750 watts RMS (300 watts per coil)
peak power handling 1,500 watts
sensitivity 87.4 dB
top-mount depth 6-13/16"
sealed box volume 0.88-2.0 cubic feet
ported box volume 1.75-3.25 cubic feet
warranty: 1 year through Indo Audio Electronics
1*
VOLFENHAG ZX-7180 2 CHANNEL
Maximum power output @ 2ohm 800W x 2 = 1600W
Power output:
3200Wx2CH@2ohm(640W)
220Wx2CH@4ohm(440W)
Bridged Power 640Wx1CH@4ohm
2ohm stable stereo
Tri-mode capable
Fan cooling system
Variable bass boost:0-18dB
Variable bass frequency:30Hz-100Hz
Channel seperation:>60dB
Signal to noise ratio:97dB
THD 0.03%
Frequency response:20Hz-20KHz
HPF:50Hz-1KHz
LPF:30Hz-250Hz
Adjustable sensitivity range:0.1V-1V
Input impedance:Low level(10K ohms), High level(100 ohms)
Dimension(WxHxL)mm:262x59x429
Håber i vil hjælpe mig!
KICKER S12L7 VOLFENHAG ZX-7180 2 CHANNEL
:D :D
