ziegler Skrevet Oktober 20, 2004 Rapporter Share Skrevet Oktober 20, 2004 Kan man godt sætte disse to enheder sammen og vil Subben blive udnyttet optimalt? VOLFENHAG ZX-8400 2 CHANNEL Maximum Power Output 1000 Watts x 2 2000 Watts Bridge Power Output @ 2 Ohm 300 watts x 2 Power Output @ 4 Ohm 200 watts x 2 Bridged Power @ 4 Ohm 600 Watts x 1 THD @ 2 Ohm <.1% Channel Separation 55dB Frequency Response 1.0dB 15Hz-30Khz HPF (High Pass Filter) 50Hz - 1Khz LPF (Low Pass Filter) 30Hz - 500Hz Subsonic Filter 10Hz - 100Hz Adjustable Sensitivity Range .2 Volts - 6 Volts Input Impedance (low Level) 10K Ohms Fuses 40 Amp x 2 Dimension (WxHxD) mm 327x38x400 og KICKER S15L7 2004 SUBWOOFER! aluminum deposit cone non-resonant aluminum basket Santoprene rubber surround dual 4-ohm voice coils for wiring flexibility frequency response 18-100 Hz power range 75-1,000 watts RMS (300 watts per coil) peak power handling 2,000 watts sensitivity 88.5 dB top-mount depth 8-1/4" sealed box volume 1.5-6.0 cubic feet ported box volume 3.0-6.0 cubic feet warranty: 1 year Indo Audio Electronics På forhånd tak:D Siter Lenke til kommentar Del på andre sider More sharing options...
