Film: BMW turbo-motorsykkel med 350 hk
Vi må ikke glemme at BMW også lager motorsykler:
K1200 RS Turbo 5psi Rush Hour (2.2 MB)
The new K1200RS Turbo is capable of 350hp @ 24 psi but is shipped set for up to 15 psi which gives a respectable 255 hp @ 9000 rpm. For the daily commute here in Southern California we turn the wastegate down to its minimum setting of 5psi. This video gives you an idea of what a BMW will do with only 5 psi:
http://www.rbracing-rsr.com/cinema/bmwmov1.mov
K1200 RS Turbo Virtual Tour (2.1 MB)
The only way you can see any of the parts is with the body panels removed. Access for normal servicing is unaffected and the ceramic coated muffler is well away from the inside of the left saddle bag. With the body panels in place there is no hint of what lies beneath :
http://www.rbracing-rsr.com/cinema/bmwmov2.mov
God (h)jul til alle!!
