Bedre enn ny?? (mange bilder)
Colour Concept
  • Svar 39
Originally posted by gondl3n
Noen som veit hvilket land den står i?
Kan ikke være Norge?
Jeg tror den bor i England, fant bildene på en engelsk side + at rattet er på feil side og gule nr. skilt bak.
Golf III Colour Concept Cab
Ford Mondeo Ghia
x-Golfen Rolf
x-Mazda 323
x-Ford Sierra is
x-Chevy Van G-20 360 police
x-opel Manta 2,0 sr
SPEC SHEET
ENGINE
200 COSWORTH BLOCK
STANDARD STEEL CRANK, STANDARD STEEL CON RODS
GENUINE COSWORTH PISTONS
LOW COMPRESSION (7.6:1)
HIGH PRESSURE OIL PUMP
BIG WINGED SUMP (extra 2 litres)
WRC METAL 4 LAYER HEAD GASKET
LONG STUDDED
4X4 POLISHED & PORTED HEAD
HARVEY GIBBS CAMS
KENT ADJUSTABLE VERNIERS
4X4 MANIFOLD
GT28 ROLLER BEARING TURBO WITH MODIFIED T34 FRONT HOUSING
GARRETT –31 ACTUATOR
GROUP A CAM BELT
GROUP A COIL
GENUINE RS500 INTERCOOLER WITH MODIFIED T34 FITTINGS
PACE RS500 FAST ROAD RADIATOR (50mm core)
PACE TURBO COOLER
BAILEY MOTORSPORT TURBO OIL FEED & PRE FILTER
SPEC-R GROUP A BREATHER/SEPARATOR SYSTEM
SPEC-R SWIRL POT
SPEC-R WATER COOLED POWER STEERING TANK
SPEC-R HEADER TANK (with sight glass)
STANT 21-25psi RADIATOR CAP WITH LEVER RELEASE
SAMCO BOOST & WATER HOSES
MIKALOR STAINLESS STEEL HOSE CLAMPS
MONGOOSE 3in STAINLESS STEEL EXHAUST (4 in tailpipe)
(with Powerflex hangers)
K&N CONE FILTER
WEBBER MARELLI LEVEL 8 ECU WITH PECTAL BABY BOARD
PECTAL 12 POSITION BOOST CONTROL (in car)
4 X 403 ‘GREY’ INJECTORS
WRC AIR INJECTORS
WATER INJECTION
044 FUEL PUMP
3 BAR MAP SENSOR
MOTORCRAFT AGP 701 SPARK PLUGS
FORD MOTORSPORT IGNITION LEADS
CASTROL RS 10w60 FULLY SYNTHETIC OIL
TRANSMISSION
STANDARD BORG WARNER T5 WITH QUICKSHIFT & LSD
LIGHTENED & BALANCED FLY WHEEL
ALCON 6 PADDLE, STANDARD FORD COVER
RECONDITIONED PROPSHAFT WITH UPRATED UJ’S
QUAIFE ATB 7 ½ INCH DIFF, 3.65 FINAL DRIVE (standard)
POWER
405 bhp @ 6030 rpm
397 lbft TORQUE @ 4020 rpm
REV LIMITER 7100 rpm
PEAKS AT 32 psi, HOLDS 28psi
BUILT & TUNED BY HARVEY GIBBS
SCS, PETERBOROUGH. 01733 576614
MAPPED BY AHMED BAYJOO ON DYNO & IN CAR
BRAKES
FRONT: AP RACING CP5555 6 POT CALIPERS
330mm x 28mm DISCS & BELLS
FERRADO DS2500 PADS
REAR: 4x4 CALIPERS
300mm x 22mm DISCS & BELLS
FERRADO PADS
GOODRIDGE BRAIDED HOSES ALL ROUND
SUSPENSION
FRONT: KONI TOP ADJUSTABLE DAMPERS
EIBACH SPRINGS –20mm
POWERFLEX BUSHES
SPEC-R TWIN BAR STRUT BRACE (chromed)
REAR: KONI BOTTOM ADJUSTABLE DAMPERS
AVO STANDARD HEIGHT SPRINGS, 30% UPRATED
FORD BUSHES
REAR SHIM KIT
SPEC-R REAR STRUT BRACE
INTERIOR
STANDARD RECARO INTERIOR
RS MOTORSPORT 3 SPOKE STEERING WHEEL
WILLINS 4 POINT HARNESSES
DEFI OIL PRESSURE & TEMPERATURE AND EXHAUST GAS TEMPERATURE
DEFI CONTROLLER (with record and playback)
APEXI 2.5 BAR BOOST GUAGE (with record and playback)
S.E.C.S MONITER
SPEC-R WATER INJECTION TANK IN BOOT
FIRE EXTINGUISHER
EXTERIOR
FRONT WHEELS : COMPOMOTIVE MO, 7 I/2in x 17in ET 37
GOODYEAR EAGLE F1’s 215/40
REAR WHEELS : COMPOMOTIVE MO, 8in x 17in ET 35
GENUINE RS500 FRONT SPLITTER
SPEC-R REAR BUMPER/EXHAUST HEAT SHIELD
Det er bare en ting å si om denne bilen....FY FAAAEN!! Verden er urettferdig.
Ford Mondeo Ghia
x-Golfen Rolf
x-Mazda 323
x-Ford Sierra is
x-opel Manta 2,0 sr
Åååånei!!!! Nei nei!!! verdens styggeste ratt!! å nei... det ødela helebilen... det var absolutt det første jeg la merke til! :P
Måtte bare... hvem driter ikke i rattet da? fyyy å strøken.
Som en vis mann sa: "Rætten i min bil er jævligt fin, men dine rattar er fan mæ special fan'"
haha... :P:P
-Erik-
