Rotordics Skiver og Greenstuff til Civic VTi (forran og bak)
SnOOpY
Nye og urørte skiver og klosser til Civic VTi selges. Kun vært pakka ut. Klossene ligger fortsatt i plastiken de ble levert i.
Effektiv og stilig oppgradering... Har kjørt 15 runder i strekk på Våler med samme type skiver og klosser på VTi... Biter bra og ingen fading. Anbefaler bytte av bremsevæske samtidig..
Godkjent på norske veier.
2 stk Rotordisc 262mm Forran 2200,- inkl frakt
2 stk Rotordisc 238mm Bak 1900,- inkl frakt
Greenstuff klosser forran 800,- inkl frakt
Greenstuff klosser bak 500,- inkl frakt
Pakkepris: 5000,- inkl frakt
kim.olsen@omya.com
Rotor Discs are direct replacement for original discs without any modification.
Enhanced cooling due to the Rotor Disc design encouraging air flow through the disc.
The Rotor Disc design also reduces the weight of the discs making them the lightest direct replacement discs on the market reducing the weight by approx 10%.Reducing unsprung rotational weight which in turn improves acceleration and reduces Gyroscopic effect improving handling.(The same idea behind Alloy and Magnesium Wheels). Example: Audi TT a saving of 1.36kg on the front discs alone.
16 grooves giving increased friction improving stopping power and allowing hot gasses to escape whilst stopping the disc and pads from glazing over, keeping stopping power throughout the life of the discs.
Unichrome Zinc plated to help prevent rust on upswept surface.
Rotor Discs have been designed to be gentle on pads whilst maintaining stopping power.
