2 forsterkere Selges!!!
krusty
Selger en Genesis profile sub forsterker, Den er ny og ubrukt,
Genesis Profile Sub
For dedicated subwoofer applications, Profile Sub has the latest Tripath technology to create a digital amplifier combining superior sound quality with huge power reserves. The high efficiency of Class T creates enormous power without the build up of heat normally associated with analogue design, enabling a modern and compact case design. Made In England
Channel: 1
Watts-Max: 1x600@1Ohm
Genesis Watts: 1 x 450(2 Ohm RMS); 1 x 250(4 Ohm RMS); 1 x 600(1 OHM RMS)
THD: < 0.1%
S/N Ratio: 100 dB "A" Wtd
Filter: High-Pass: 20 - 200 Hz; Low-Pass: 50 - 200 Hz
Size: 300mm(L) x 232mm(D) x 38mm(H)
Denne er målt til ca 530 watt rms i 2 ohm, forsterkeren er hånlaget i england, og er sinsykt bra, Ny pris på denne er over 5000 kr, selges kunn kr 2500 kr
http://www.sound-offs.co.uk/img/genesis/profile_sub.jpg
Selger også en så og si helt ni velocity vr 1002, Kunn brukt en uke i bilen min, Tror dette er den største forsterkeren til velocity,
Power 600 W
2 x 200 W oder 1 x 600 W. Power (4 Ohm)
2 x 300 W Power (2 Ohm)
2 x 100 W oder 1 x 300 W Sinusleistung (4 Ohm)
2 x 150 W Sinusleistung (2 Ohm)
10 - 70.000 Hz Frequenzgang
Subsonic Filter
BassBoost
Druckguss Kühlkörper
End caps
optionale DSP Fernbedienung
482 x 72 x 290 (BxHxT in mm)
Ca 1200 w borkoblet i 2 ohm, denne drar det meste, Ny pris, ca 5000, Selges kr 3000. http://www.mybugasound.com/tienda/catalogo/www/dom/datostiendaplus/0001/productos/VR1002_p.jpg
1991 peugeot mi16
