toe-in grader
Zievert
jeg fikk denne mailen av en som selger justerbare camber kits:
"Good morning,
Yes, the camber kit is design to help reduce the negative camber caused by
lowering. It's really the only solution for removing / reducing the negative
camber, with the idea of still leaving a small amount of toe-in. With 40mm of
lowering, the kit will most likely not eliminate all of the negative camber, but
I would expect to be able to dial up to 1 degree out. From a handling
perspective, it's good to keep some negative camber for handling reasons (this
is why a stock 1995-1999 M3 comes with -1.5 degrees of camber from the factory)."
han skriver: It's really the only solution for removing / reducing the negative.
er det det?
hvis det er det så må jeg jo bare kjøpe det kittet.
