Ford har skjønt det!!
Volvo240R
kjapp google:
* Used from 1993 on the 850, S70 and V70 models
* 2.4 liters
* 5 cylinders
* Double Overhead Camshaft (DOHC)
* Aluminium block, crankshaft and connected rod made of forged vanadium
* Electronic ignition with knock sensor
* Self diagnosis system, from 1996 the OBD-II system is used
* 4 valves per cylinder, 20 valves total
* Firing order 1-2-4-5-3, number 1 piston on the timing belt side
* Oil capacity with filter: 6.1 quarts (7.0 quarts on Turbo when oil cooler is drained)
* B5254S is the non-Turbo version giving 168hp. This engine is fond on base models.
* B5254T is a low pressure Turbo version giving 190hp. This engine is found on many models including the GLT and AWD.
* 3 different fuel injection systems were installed depending on the year, model and market
* Bosch LH Jet 3.2 fuel injection with EZ-129K ignition system
* Motronic 4.3
* Motronic 4.4
B5254T 1993-1997 2400 Bosch LH 3.2
Motronic 4.3
Motronic 4.4 190 5100 199 1800 9.0:1
Hentet fra http://www.vlvworld.com/indexframe.html?engspecs.html
tips for å finne bilder ..
på på google.com/.no og søk etter "Ford Focus ST" og så velger dere en av sidene også klikker dere på den.. eller så kan dere gå inn på http://www.bilnorge.no og søke etter focus ST der finner dere også en del bilder
[*] 2003 Lexus IS200
[*] 1999 BMW 318i - Solgt
[*] 1998 Mitsubishi Carisma GDI - Knust
